Old 2nd February 2011, 03:43 PM   #1
Default suggestions on a suitable amp for ZD5.
I've been going back and forth between building zaph's sr71 and his zd5. Partially because I've realized I'll probably need to build a more expensive amp in order to get the most out of the zd5. (I've only got a pos sony surround amp currently). I'm pretty set on building a myref rev C if I go with the 71's. I know how to solder though its been 20+ years since I've done it, can stumble through a schematic, and have a friend with an oscilloscope. Ideally I'd like to just build a great integrated amp that will run the zd5s to their full potential without me having to break the bank or get a degree in ee (kits are preferred but not a deal killer). I listen to jazz, classical, hiphop and alternative rock (I'm not a fan of boomy base, or overly loud systems).
Any ideas on amps for the zd5? Thanks in advance!
Old 2nd February 2011, 04:12 PM   #2
DougL is offline DougL  United States
Look at the Firstwatt F5.
You can add a pot to make it an integrated.
DIYAudio sells circuit boards.
25 Watts, simple, sounds good, will drive complex loads.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 2nd February 2011, 06:00 PM   #3
lloop9 is offline lloop9  Singapore
I second the F5 too. In fact, if you have balanced source, then wait for the balanced F5 optimized by Patrick for 6 ohm load at 46 watts if I remembered correctly.
Also, you may want to look at the Danish-made Scan-speak Discovery R2604/8320 Ring Radiator Tweeter in place of the Chinese-made XT25, both are identical but the Scan Speak uses German made dome like the old Vifa.
Old 2nd February 2011, 08:56 PM   #4
thanks all Icve been looking at the f5. The balanced f5 seems attractive and a very interesting idea, as I'll be running from a digital sourceAny idea on what total parts cost on it would be and when kits will be available? looks like at least 200usd for just the heat syncs.
Old 2nd February 2011, 09:50 PM   #5
weskoki is online now weskoki  Europe
weskoki's Avatar
Not shore if 25 watts is enough for the ZD5.I had the F5, now i'm finishing the Myrefc
Old 3rd February 2011, 07:17 AM   #6
If you don't mind me asking what speakers were you running with the f5? I am assuming that because of the switch to the myref you were dissatisfied with the f5. What in your opinion, were the failings of the f5 and your speaker combination? It would be interesting to get your impressions of both the f5 and the myref (when you have completed it) as they are very different beasts.
Old 3rd February 2011, 11:20 AM   #7
weskoki's Avatar
Wish someone would clone this baby lenehan ml1
Old 4th February 2011, 06:41 AM   #8
There are a few guys building the first run to iron out the details, after which there will be pcbs for sale, BOM & stuff. So wait for them to finish building & testing then we'll know the cost. Its worth the wait.
Will you be building the sealed or ported version ZD5? Do post your build here so we can learn & drool at the pix.
Old 4th February 2011, 09:13 AM   #9
thanks for the info. I actually read all 87 pages of the thread after your suggestion, seems like one hell of an amp, im afraid it might be a bit advanced for my skill set. Maybe I can find someone willing to do the electrical work for me for a fee, with all those expensive comoonents I'd be afraid to fry it buy messing up . I'll be building the sealed version of the zd5. though it wontbe until september or so. I'm headed home to the.us for the summer, so I'll be buying parts there andbring them back to sweden.
Old 4th February 2011, 06:09 PM   #10
weskoki's Avatar
What kind of speakers have you had?
Suitable woof & tweet for CV Full Range chip amp? lunchmoney Chip Amps 3 20th March 2011 06:00 PM
ecl86 & ez80 - suitable for guitar amp? greenstax Tubes / Valves 20 22nd August 2007 10:10 AM
suitable amp for this subwoofer? mcshaggy Subwoofers 3 2nd March 2005 05:03 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
Page generated in 0.10693 seconds (78.02% PHP - 21.98% MySQL) with 11 queries
