Back Loaded Horns Back Loaded Horns - Page 7 - diyAudio
Back Loaded Horns
Back Loaded Horns
Old 5th February 2011, 05:29 PM   #61
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
The same Vtc raised to 9 litre. 0,5phi
File Type: png Schermafbeelding 2011-02-05 om 19.27.47.png (30.9 KB, 684 views)
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 5th February 2011, 05:57 PM   #62
Helmuth's Avatar
A other driver that I advised because it has low THD and big x-max it is very use-full for active compensation of the low-end.
With active compensation -3db at 30Hz (xmax5,5mm 128W) max spl within x-max is 113dB 1mtr.
With this results it is possible to have a horn that extends to 30Hz with a max sound pressure of 113dB in the living room.
0,5 phi
Back Loaded Horns-schermafbeelding-2011-02-05-om-20-00-43-png
File Type: png Schermafbeelding 2011-02-05 om 19.47.51.png (31.3 KB, 776 views)
File Type: png Schermafbeelding 2011-02-05 om 20.00.43.png (30.8 KB, 1613 views)
Old 5th February 2011, 06:20 PM   #63
GM is offline GM  United States
GM's Avatar
Originally Posted by Helmuth View Post
It is the predicted response from the mouth output............
My point is that for the horn to do pretty much all the filtering requires the roll off response to include the driver's pistonic output, i.e. true band-pass (BP) which without inputting your design doesn't seem to be the case.
Anyway, instead of posting a response plot, please export HR's file as a .txt file to attach to your posts, so that we can download and export it to HR to see and/or save the design.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th February 2011, 06:27 PM   #64
GM's Avatar
Originally Posted by Lynn Olson View Post
That's why I'm curious about curved horns - would they have less problem with notches than a folded horn, or not?
Yes, if a Nautilus style expansion as WE proved early on with its early ultra wide BW horns.
GM
Old 5th February 2011, 06:42 PM   #65
Helmuth's Avatar
GM
Here you are.
Old 5th February 2011, 11:50 PM   #66
GM's Avatar
I meant export the 'input parameters' table (HELP pg. 8). It should look like this except with your design's data of course:
GM
File Type: txt 123.txt (416 Bytes, 19 views)
Old 6th February 2011, 08:11 AM   #67
Helmuth's Avatar
GM
Ok?
Beyma SM115N driver to make active extended response down to 30Hz.http://profesional.beyma.com/pdf/SM-115%20NE.pdf
low thd
Back Loaded Horns-schermafbeelding-2011-02-06-om-10-27-31-png
2PHI
Back Loaded Horns-schermafbeelding-2011-02-06-om-10-15-31-png
1Phi
0,5PHI
File Type: png Schermafbeelding 2011-02-06 om 10.15.31.png (31.2 KB, 740 views)
File Type: png Schermafbeelding 2011-02-06 om 10.27.31.png (41.6 KB, 737 views)
File Type: txt spa15pa.txt (400 Bytes, 12 views)
File Type: txt beymasm1.txt (405 Bytes, 17 views)
Old 7th February 2011, 01:43 AM   #68
LineSource is offline LineSource  United States
LineSource's Avatar
From what I understand, the Klipsch Jubilee was the best rear horn design from the Klipsch engineering staff. I've attached a few pictures for discussion.
Old 7th February 2011, 06:04 AM   #69
Helmuth's Avatar
It is a front loaded horn just like the La scala only a longer horn to get a lower cutoff frequency.
A Longer horn is better to get more subbas but it is less desirable for mid frequency. That is the problem with making design choices to get a advantage you encounter a disadvantage
Old 26th February 2011, 04:04 PM   #70
Helmuth's Avatar
Some one who likes to see this from a frontloaded horn with br-port ?
-6dB 25Hz.
Download your specs here. sp12/100pa
MONACOR INTERNATIONAL:Produktdetailseite IMG Stage Line
Back Loaded Horns-hornresp-pdf
Back Loaded HornsHide this!Advertise here!
How to model Back Loaded horns in Hornresp? Boscoe Full Range 2 17th January 2011 08:00 AM
Sub amp phase w/ back loaded horns (again) wicked1 Subwoofers 6 4th August 2010 04:52 PM
The Best Program for Back Loaded Horns Patrick Bateman Full Range 2 21st December 2009 04:04 PM
Op amps and back loaded horns MikeFarad Full Range 1 1st January 2007 04:50 AM
FE206E Back Loaded Horns and ML TL Illusus Swap Meet 6 23rd February 2005 06:35 PM
Copyright ©1999-2017 diyAudio
