Old 31st January 2011, 12:24 PM   #1
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
Default 10'' or 12'' OB coax drivers
I saw the 10'' Hawthorne coax, and wondered how well it might mate sitting atop my MJK 18'' H-Frame Goldwoods ? Baffle could be up to 24''w x 30''H if need be.. Could they play strong to 70hz or so where the GW drivers come in?
Any other better candidates for a 10" or 12" coax to be run off a 6watt SEP without eq etc?
Has anyone listened to the Hawthorne SI 10'' coax?
Specs: Silver Iris OB 10 Coaxial Unit [SI-OB-10] - $160.00 : Zen Cart!, The Art of E-commerce
Old 1st February 2011, 12:17 PM   #2
DaveCan's Avatar
So no one has heard the SI 10'' coax, or have any info or opinions on them or other possibilities??
Old 1st February 2011, 02:40 PM   #3
Godzilla's Avatar
I think it would be a very good candidate. Curious about the SI drivers. I see they use a little Eminence tweeter and wonder what their 10" driver is? Is it the Eminence 10" coax modified to work better on open baffle or something else?
Old 2nd February 2011, 01:47 AM   #4
It's an Eminence cast frame driver build to custom specifications for open baffle use. It's available configured with the little Eminence compression driver and also a higher end unit with a Radian compression driver. I've also designed a two-way with the 10" Hawthorne and a B-G Neo3 planar magnetic tweeter. Good stuff!
Old 2nd February 2011, 02:39 AM   #5
LineSource's Avatar
Hi Dave,
I have never heard the Silver Iris 10" speaker. The small Xmax could limit your dipole options. I ran the 2.3mm Xmax woofer on your 24" wide baffle through Linkwitz's SPL calculator(free on his site) and got the table below estimating a maximum of 92db @ 1m.
Personally, I favor 8" - 10" midrange drivers for dipoles and currently have both the Tang Band W8-1808 (Xmax=5mm) and the Lambda TD10_dipole (Xmax=14mm) on exchangable baffle boards.
SILVER IRIS 10" WOOFER SPECs: 2.3mm Xmax
Heavy cast frame basket • 2" voice coil • Power handling: 150 watts RMS • Impedance: 8 Ohms • System Sensitivity: 94.2 dB 1w/1m • Le: 0.78 • Re: 7.80 Ohms • Qt: 0.68 • Vas: 79.1 liters • Xmax: 2.37MM • Fs: 54.3Hz • Magnet weight: 38ounces
Freq dipole
Hz dB SPL
25 65
35 74
50 83
71 92
100 101
141 110
Old 2nd February 2011, 05:44 AM   #6
blakkshepeaudio's Avatar
Greets.
In passing, does anyone have any experience / opinion regarding the Eminence Beta-10CX which is available in Australia for about AU$250 each (A$ and US$ near as equal at the moment) or the Beta-12 CX which is the same price?
This include the throat adapter and an APT50 compression driver.
Nothing is cheap in OZ......
I am happy to mess around with cabs but would like a solution (actively crossed over) that I can use to try out various things and a decent coax would be ideal.
Keith Arnold
p.s. Driver will be tried in a variety of cabs BR/BVR/BLH/MLTQWT/BIB, fullrange and with a sub. Xover will be a minidsp. Fun and research the name of the game......
Old 2nd February 2011, 07:31 AM   #7
el`Ol is offline el`Ol  Germany
Ciare HX255 would do bass even lower in large OBs but is not suitable for SE from its sensitivity.
http://www.ciare.com/pdf/catalogo/HX255.PDF
with a weak motor that enables 70Hz in OB it's doubtful anyway that this would be possible, unless one would develop something with light diaphragm, for which there is no market in the pro world. And 70Hz with 24" can only be done with U-frame, I don't know whether this is an option for you. You will probably be better off with a normal strong motor pro coaxial and higher crossover point.
Old 2nd February 2011, 03:40 PM   #8
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
b&c(8")B&C SPEAKERS
12" 4mm
B&C SPEAKERS
bms 12" 5,5mm xmax
Overview
RCF 12" 5,5mm xmax
RCF - CX12N351
RCF 10" 4mm x-max
RCF - CX10N251
Beyma 10" 5mm x-max
http://profesional.beyma.com/ingles/pdf/10XC25.pdf
beyma 12" 5mm x-max
http://profesional.beyma.com/ingles/pdf/12XC30.pdf
18sound 6,5mm x-max
12CX800 - High Output Coaxial Ferrite Transducer
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 2nd February 2011, 03:45 PM   #9
Helmuth's Avatar
KM30
PHY-HP (Haut parleurs)® - KM 30
Most recommended Coax for OB? Jeroenkv Multi-Way 8 19th May 2009 06:32 PM
Cheap OB coax? jimluu Full Range 2 31st July 2008 03:43 AM
PAudio Coax on an OB abmoggy Multi-Way 7 30th March 2007 07:04 AM
10" Coax in OB inrank Multi-Way 27 12th September 2006 02:20 PM
high efficiency 10-12" midbass drivers Puggie Multi-Way 3 19th August 2005 03:35 PM
Page generated in 0.11702 seconds (77.27% PHP - 22.73% MySQL) with 10 queries
