Old 28th January 2011, 04:47 PM   #1
Default which 8" driver for DIY build?
I'm building a center channel speaker that will go with my kilpsch main speakers. I need help with the woofer selection. My box will be 31 x 11.25 x 19. I will wire these in series to get a 8ohm load. They will crossover at 700hz to the mid. Here is the driver I'm thinking of using.
Eminence Alpha-8A 8" PA Driver | Parts-Express.com
Old 30th January 2011, 05:31 AM   #2
Nothing?
Old 30th January 2011, 08:35 AM   #3
Francec is offline Francec  Australia
Banned
Don't be too impatient. This will give it a bump too.
Old 30th January 2011, 10:13 AM   #4
hotiron is offline hotiron  Scotland
hotiron's Avatar
These Alphas are no use for domestic audio.
What kind of budget are you on?
Woofer Selection Guide at Parts Express
This one is cheap with great spec.
http://www.parts-express.com/pe/show...number=295-356
If you give up easily Dont start!!
Old 1st February 2011, 05:41 PM   #5
Dayton Audio RS225-8 8" Reference Woofer | Parts-Express.com
Since I need two 8" woofers for this project, I wanted to keep the cost around $50 each. The mid and tweeter are from a Klipsch Heresy so I was trying to get a high spl woofer.
Old 1st February 2011, 05:52 PM   #6
Default Use Beta 8 instead
I heard a nicely done MTM that used two Eminence Beta 8s and a compression horn tweeter, crossed at 1.2k. The efficiency of these drivers was so high that a 15W class-A amp was plenty to drive them to very "realistic" levels. Imaging was excellent.
It's speaker #9 on this page, from a recent DIY meeting in northern California:
Meet-Spring2010
-Charlie
Old 1st February 2011, 06:34 PM   #7
Thanks for the info! I have klipsch speakers in my home and am looking to add a new center channel. I will use the klipsch type E crossover 700/6000 along with the K-55v mid horn and the K-77 Horn tweeter. The standard K-22 12" woofer was made by Eminence, but the Heresy speaker was too large for my TV stand.
I'm running the my system with a B&K AVR507 so it has plenty of power, but then I do like it loud.
Old 1st February 2011, 07:41 PM   #8
Godzilla's Avatar
The Alpha or Beta 8" drivers are certainly a good way to go with your Klipsch mid/tweeter components. Not sure there is anything else out there that would even be efficient enough to work with the rest of your system. Whichever you choose should work nicely.
Good luck.
Zilla
Old 1st February 2011, 08:05 PM   #9
How about this one if it is available where you are:
MONACOR INTERNATIONAL:Ergebnis
And again in english:
http://www.monacor-ost.com/catalogue...=62&SubKtg=679
my first DIY speaker build: "cheapowave" econowave implementation.. zog666 Multi-Way 2 26th January 2010 11:47 PM
Some 8"/5"/4" driver DIY...... India sumit Full Range 8 18th November 2009 10:26 AM
Best DIY sub for 18" driver juxta Subwoofers 31 9th November 2009 07:43 PM
Project "The Drummer"-Flat DIY sub driver ZuMbAiU Subwoofers 0 28th January 2006 10:40 AM
Page generated in 0.10059 seconds (87.14% PHP - 12.86% MySQL) with 11 queries
