Folks,
I have some compact floor-standing cabinets that I would like to re-use for my first DIY project. I choose to go with an existing cab instead of building my own because I want to see what I can do with a DIY design before tooling up and buying wood for a full build. So right now, I have the empty cabs of an Infinity Reference 2000.5 that I plan to re-use. I have cut out the existing baffles and plan to use a new custom cut baffle. Since I am re-using the cabs, I have to find a 2-way design that can work with the cab parameters. Which are Interior Volume - 1.3 Cubic feet (About 35 litres) It has a 12 inch long port (3 inches dia) which can be sealed if I wanted to. Drivers - The new baffle width is 7.5 inches and I have about 12 inches to play with vertically. Looks like I have two choices for a driver combo 1. 6.5 or 7 inch mid/bass driver and a simple dome tweeter or 2. 6.5 or 7 inch subwoofer/dedicated woofer with a 2 inch full-range on the top. So my question is, is there a well regarded two way design that can use about 35 litres of cab volume ? I am especially intrigued by the option of using a 2 inch full range on the top so I can get a dedicated subwoofer for the low-end. The original speakers had a low-end of 38hz at -3dB. I was hoping to better that by using a dedicated woofer and full range combo. Here are what the cabs look like..
#2 |
May I steal Sreten's (Diyaudio member ) bookmarks ? Many projects available on the net ,sure you'll find the one that fits.
undefinition Zaph|Audio FRD Consortium tools guide RJB Audio Projects Speaker Design Works HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs. Humble Homemade Hifi DIY Loudspeaker Projects Troels Gravesen |
#3 | |
#4 |
#5 |
The box size will pretty much limit how low it will play. I think one of the Peerless 6.5" HDS drivers may go as low as 40 hz F3 in that box. It would use a conventional tweeter, or a full range if that is your preference.
#6 | |
Usher 8836A - 28 Hz - (0.26 QTS) Madisound 6102-4 - 28.6 Hz - (0.26 QTS) Adire Extremis - 30 Hz - (0.332 QTS) Aurum Cantus AC-165 - 32 Hz - (0.37 QTS) SB Acoustics SB17NRXC35-8-UC - 33 Hz - (0.33 QTS) Peerless 831735 - 38 Hz - (0.43 QTS) Tang Band W6-1139SI- 38 Hz - (0.4 QTS) |
#7 | |
#8 | |
Dayton DA175-8 (39 Hz Fs and 0.58 QTS) - This is pretty affordable. Dayton RS180-4 (40Hz Fs and 0.5 QTS) HiVi D6.8 (43 Hz Fs and 0.45 QTS) GR Research M-165X (40 Hz Fs and 0.44 QTS) As you pointed out, the peerless driver still seems a pretty good choice.. |
| Subwoofer Amp Design Suggestions | SpikedCola | Chip Amps | 45 | 28th February 2011 01:31 AM |
| Driver or design suggestions | Ling Gowa | Multi-Way | 1 | 25th February 2010 04:12 AM |
| SDX15 x2 ...design suggestions please | Oscillate | Subwoofers | 4 | 7th October 2007 09:13 AM |
| Suggestions on my crossover design? | JoeyDD | Multi-Way | 11 | 11th December 2005 02:05 PM |
| Suggestions On Tuning This Design | OMNIFEX | Multi-Way | 11 | 28th April 2003 05:30 AM |
| Page generated in 0.11941 seconds (83.16% PHP - 16.84% MySQL) with 10 queries |
