Old 26th January 2011, 09:21 PM   #1
Default My Audio Physic Avanti IIIs have a lower-MR driver that covers 200 - 500Hz...
...and a virtually identical MR driver that covers the more-normal range of 200 - c. 2500Hz. These 2 drivers are driven by separate sections of the x-over, of course. In improving the sounds of the speakers--and boy have I ever!--I've removed both sets of 200Hz-MR-hi-pass caps from the boards and replaced them with smaller coupling caps in my poweramps. I chose a filter point of a bit below 100Hz to warm the sound of the system, and so far it works very well. I don't play the system to ear-numbing levels, so the MR-hi-pass filter point that's more than one octave lower is quite safe.
I'll soon be receiving a pair of Monaychy Audio SM70 Pro poweramps and plan to vertically biamp these 2 drivers (they're already wired to be able to do that). That way I'll get the same amount of total power from the four channels of the 25WPC-into-8 SM70Ps that I'm getting from the two channels of a pair of 50-into-8 Marantz M-22 monoamps.
FINALLY the 'question'. I'm thinking about choosing two different MR-hi-pass filter points for the 2 drivers, say c. 50Hz for the lower-MR driver and c. 100Hz for the MR driver, mainly for increased power handling/driver safety. That way the lower-frequency driver would carry the 3-1/4 octaves from 50 - 500Hz while the other would carry the 5-1/2 octaves from 100 - 2.5KHz. What do you think? Would there be cancellation effects in the 50 - 100Hz range because of the 2 different filter points?
BTW this is NOT a D'Appolito (sp?) or other MTM configuration.
BTW2. The diffractionbegone.com tweeter pad increased the quality of the treble substantially on the Avantis and also on a VonSchweikert Visiun; I highly recommend them.
Upgrading Audio Physic Tempo 2 studiostevus Multi-Way 2 24th October 2010 01:26 PM
Audio Physic Avantis and DIY improvements jeffreybehr Multi-Way 1 18th September 2010 06:34 AM
Which Driver to use for 100hz-500hz? KCCT82 Multi-Way 27 6th January 2008 03:59 PM
Speakers like Audio Physic and VA? seve Multi-Way 0 5th August 2005 08:23 PM
Audio Physic Virgo baffle thickness? Nordmann Multi-Way 1 17th March 2002 12:40 AM
Page generated in 0.07012 seconds (68.73% PHP - 31.27% MySQL) with 10 queries
