What are the variables for Voice coil inductance in speakers? greater length of VC equals increased excursion but greater inductance hence loss of transient response? Ie.,it won't produce the higher frequencies well? Is that it?
Also does a wider diameter VC equal lower inductance but less strong B field? I notice visually the mid/woof in the Magico mini seems to have a much smaller VC than the famous Scanspeak midwoofs. Is this part of the reason it has stat like clarity? Superb transients? I know it is underhung whereas the Scanspeaks are overhung I think. Is VC inductance the most important parameter when designing a Direct Radiator? Thanks in advance. |
#2 |
N squared A over L is the approximate formula.
N is the number of turns and is squared, so double the number of turns will give 4 times the inductance. A is the area of the circle incribed by the coil diameter (pi r squared), and L is length from top winding to bottom. B (actually motor strength, B is magnet strength) is primarily related to the volume of copper in the gap. You can slice the copper thin for high DCR or thick for low DCR, but more copper is better. In the end inductance prevents current from flowing at high frequencies, so it is one of the natural limits causing HF rolloff. Note that slicing the copper thinner will increase R and L at the same time. I think DCR and L would go up in proportion so the cut-off point wouldn't change. It is the ratio of inductance to DCR that sets the cutoff point. Finally, the voice coil inductance includes a loosely coupled iron core so it gradually rises rather than having a straight 6dB per octave rise. This also means the rolloff effect is gradual. David S. |
#3 | ||||
Le is most strongly affected by the presence or lack of shorting rings in or near the gap than by winding height Quote:
#4 | |
6" driver, 1 kHz, 0.52mH and a large 75mm VC. http://www.morelhifi.com/products/pd...20EW%20638.pdf Tighter gaps is said to increase flux, and square threads will allow more thread material for a given VC length. Now my memory is blank, but I think I recall there are even more to the issue than this. Wasn't it Dan Wiggins who did a test and concluded that VC inductance is an important parameter in controlling the transients of a driver? And if I may borrow the thread, for an inductance question? When can inductance be considered to be low, an in a low inductance driver? Last edited by buggsson; 28th January 2011 at 06:32 AM. |
| Voice coil inductance effect | karagiosis | Subwoofers | 8 | 5th September 2009 04:04 PM |
| HiVi B3s voice coil inductance - How to calculate? | chylld | Full Range | 2 | 15th January 2009 07:10 PM |
| FE127E voice coil inductance for Zobel calculation | arjscott | Full Range | 3 | 7th February 2007 01:42 AM |
| Measuring voice-coil self-inductance | Klimon | Multi-Way | 4 | 19th November 2006 12:23 PM |
| voice coil inductance VS transient response | kan3 | Multi-Way | 12 | 9th February 2004 08:18 PM |
| Page generated in 0.10486 seconds (77.08% PHP - 22.92% MySQL) with 10 queries |
