Suggest me a speaker to build (first timer)
Old 26th January 2011, 05:42 PM   #1
toufu is offline toufu  United States
Smile Suggest me a speaker to build (first timer)
Hello fellow diyers, after building several amps, preamp and digital sources, I want to try building my own speakers. I have a pair of Zu Druids that I am pretty happy with, these are full range speakers with a super tweeter, they are also very effiecient (101db).
My collection of amp's include F3, F5, ICEPower ASP1000 and LM3886 PA150, out of those, PA150 is my current favorite.
I am thinking of getting a premade cabinet from Madisound, as well as getting the tweeter and woofer from them. Which woofer and tweeter should I get? I want to start out with a bookshelf size, unless somebody has anything against them. Also, I want them to sound better than my Druids, how much would I have to spend to achieve that?
Thanks!
Old 26th January 2011, 06:00 PM   #2
weskoki is offline weskoki  Europe
weskoki's Avatar
Hi! You use the PA150 on the Druids? Aren't the F5,F3 better match for efficient speakers?
I wonder if you could top the Zu with Diy speakers...
Old 26th January 2011, 06:14 PM   #3
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
For a bookshelf. This looks nice to me ribbon tweeter and alucone lowmid will give a detailed reproduction.
https://www.madisound.com/store/prod...oducts_id=8503
For the real reproduction something with a woofer. Like this.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 26th January 2011, 06:30 PM   #4
I liked the PA150 better than my next favorite (F3) because of its details and bass.
Thanks for the suggestion Helmuth, can you bi-amp these ribbon tweeters?
Old 26th January 2011, 07:12 PM   #5
Helmuth's Avatar
Active filtered or with a passive filter. Not straight then it will blow by to many power and will also not sound right.
Old 26th January 2011, 08:07 PM   #6
ScottG is offline ScottG  United States
Thanks!
Getting a particularly "dynamic" sounding speaker with decent bass extension usually requires a LOT more interior volume and the use of higher efficiency drivers.
In other words it will be tough to come close the Zu for these aspects in a small typical "hi-fi" loudspeaker. On the other hand you can get better aspects in other subjective areas.. like detail, imaging, and sound-staging. You can also always use a sub (with a high-pass filter for the small loudspeakers) to "fill-out" most of the low freq. extension and a fair bit of the "dynamics".
A design that I often recommend for an overall balance of virtues at a decent price is Troel's "Poor Man's Strad".. it is however larger than any bookshelf speaker and it does require some wood-working.
With respect to your current plans:
Most of the cabinets on offer still require wood-working for the front baffle. Parts Express has similar cabinets, and perhaps more attractive ones. In particular their "gloss-black" cabinets are a particularly good value considering the amount of work that requires.
This is a design you might like that makes use of a small pre-built cabinet:
The Seas ER18DXT ported two way
ZaphAudio of course has others..
Also, try looking through HTGuide's "Mission Accomplished" section:
HTGuide Forum - Missions Accomplished!
perspective is everything
Old 27th January 2011, 04:01 PM   #7
Helmuth's Avatar
That is a very nice speaker scott. I have to second your advise.
Only thing the author of the topic wanted to use a prefabricated enclosure.
Old 27th January 2011, 06:14 PM   #8
Thanks guys, my carpentry skill is lacking, that's why I want to get something premade. But I am pretty sure I can saw off a round hole in the front (they are made out of wood, not metal, right?)
I am going to start out with a project of $800 or so for bookshelf size speakers (walking before I can run), with premade enclosure. And if I find them better than my Druids (except for the bass part, perhaps), I will move on to bigger sizes. Does that sound like a descent plan?
Suggest me a speaker to build (first timer)Hide this!Advertise here!
First timer build - Advice nightanole Chipamp 0 8th January 2010 06:37 PM
suggest a KT88 SE to build matthew2456 Tubes / Valves 4 5th August 2006 05:23 PM
I'd like to build a sailboat racing timer... chipco3434 Everything Else 6 20th July 2006 10:42 AM
Build 12V to 220V inverter from 555 timer Astro Power Solid State 1 4th December 2004 02:49 PM
Do u suggest to build ur own stereo mixer? Ze Analogue Source 2 9th May 2004 10:49 AM
Copyright ©1999-2017 diyAudio
