#11 |
Glad to hear that you have mains power experience, and hopefully a healthy respect for the damage it can cause. I think Andrew is just expressing concern for your safety. There are a lot of people who come here and seem to know nothing, and we fear for their safety if they work with mains power.
So, are you planning an active crossover or passive? If active, are you interested in DIY analog, DIY DSP or a commercial crossover? Do you have measurement gear (a calibrated microphone and a preamp)? What are your goals for this system? I just noticed your comment about winding inductors. Google inductor calculator, there are a few references that will help you figure out what you need to do. There are also a couple threads here about DIY inductors, IIRC. Do you have a source for 14 ga. magnet wire? for a couple pieces it will probably be about the same cost to purchase and wind your own. |
#12 |
It seems to me that Viki-v2 has too many projects in mind - classic 'eyes too big for stomach' approach.
My advice is to pick one - do it, finish it, then move on to the next project. You will learn a lot and folks here will be happy to help if they see you are actually doing something. |
#13 |
#14 |
Yes , i will soon start the project.
#15 |
hello Everybody,
MJL21193 Can you share the layout of all in one jig for speaker workshop, |
#16 | |
More than 250 posts worth of 'sharing'
#17 |
Check this link for proper way to implement active (or passive) crossover :
http://www.auratronsystems.com Then click "3PX8" "Design Philosophy". This is a user-friendly explanation of factors you should consider. |
#18 |
Alex, you are starting to sound like you are shilling for auratron. As discussed in Charlie's thread there's a bunch of options and all engineering involves tradeoffs. That is one design philosophy but there are other equally valid philosophies. Each designer will choose his or her own priorities and design accordingly.
Viki - are those your measurements? I would have expected to see a larger bobble in the impedance curve at 2KHz where that response glitch is. How does your tweeter do down low? With woofer response like that, I'd try to cross as close to 1Khz as your tweeter will allow. You'll probably want a high order filter - like a Cauer with at least an 8th order initial roll off to protect the tweeter crossing low. That would also work well on the low pass to push down the woofer anomalies above 1500 Hz. Realistically, that woofer is begging to be part of a three way system. |
#19 |
#20 | |
What is the point of a person's fruitfull experiences if they cannot be shared with others? |
| Designing a crossover | oldbar | Multi-Way | 2 | 2nd February 2009 11:48 PM |
| Designing my first crossover, 2-way, advice on drivers needed... | nerd of nerds | Multi-Way | 10 | 10th November 2005 12:35 AM |
| Help for Crossover Designing for 3 way speaker | CH2 | Multi-Way | 16 | 9th April 2004 04:01 PM |
| noob needs help designing crossover | helpmeplease | Multi-Way | 3 | 21st December 2003 11:22 PM |
| Need help designing crossover | soundNERD | Chip Amps | 27 | 7th December 2003 02:08 AM |
