Old 23rd January 2011, 05:02 PM   #1
reking is offline reking  Norway
Default Possible to repair woofer? It's buzzing
Hello, I'm a complete beginner to audio stuff, so bare with me.
I receieved some old loudspeakers from my dad, they seem quite nice. They are Mission Cyrus 780s. However one of them seems to resonance annoyingly at low frequencies. I have uploaded a video to youtube showing what I mean.
YouTube - Woofer rattle (I tried filming it fom different angles but there's nothing to see really, just listen to the high frequency noise that comes when I apply a low frequency (between 50-100 hz sine wave)
Now from reading a little bit about this, it could be the spider-thingy that has come loose, perhaps simply because the whole thing is kind of old. I never played them very loud. Gently pushing the cone in makes a very small "clicky" sound, which I can't seem to hear on the working woofer. Is this something I should even begin to think about attempting to fix myself? Can I get a replacement woofer easily?
Old 23rd January 2011, 05:28 PM   #2
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
Forget that chassis and try to get the same speaker for cheap if you have fallen in love with those.
There are replacement parts - but mostly for PRO chassis only - not for HIFI speakers.
As far as I know Misson has used chassis specifically made for them, at least with their newer lines.
From your video it sounds to me as if the voice coil no longer is perfectly glued to the membrane.
If you hear a rubbing sound when gently moving the cone then the VC is no longer in the center of the gap and remounting the chasis upside down some times helps - but a "click" as you mentioned - no idea...
(possibly the VC former has bottomed once and got damaged at its end - so no longer fit into the gap precisely)
If you are curious, you can always try to open the spider but you should not expect to being able to repair this speaker - sorry.
Michael
Old 23rd January 2011, 05:36 PM   #3
mige0's Avatar
Possibly also check if the litz wire to the membrane / VC is not sloppy
Michael
Old 23rd January 2011, 06:05 PM   #4
I had similar problem. it was detached cone. try to push cone out and look if there are any gaps between voice coil former and cone. if there is, just glue it back together.
Old 24th January 2011, 08:55 AM   #5
Thanks for the replies.
I'm not familiar with all these terms so I had to look them up. Mounting the chassis upside down or sideways didn't change. The wire does not seem sloppy or loose. I can not see any gap between the cone, but it may not be visible... To glue it back together, I'd have to take it apart first, no? The whole thing has no screws, just used glue to sit together. I think it will be hard to re-do it, and I may just have to look for new speakers.
Old 24th January 2011, 03:47 PM   #6
mige0's Avatar
B&K AVR-202i DIY repair possible? Relays buzzing (I think) - otherwise normal? ZepOfLed Solid State 84 8th August 2009 04:46 AM
Woofer repair? Brion55 Multi-Way 6 2nd March 2009 11:47 PM
woofer replacement/repair runnin_on_mt Multi-Way 0 17th April 2008 08:54 PM
Where to repair buzzing transformer? kyrie48 Parts 2 11th January 2007 05:04 AM
Page generated in 0.09344 seconds (77.15% PHP - 22.85% MySQL) with 10 queries
