Hi, been looking to improve my ATC SCM-7's and came across these, after being interested in a Volt Bass driver based speaker for quite some time now.
Got them home and they are not too bad. Treble detail is especially good, very smooth, accurate and clean! But it lacks midrange and the two drivers dont seem to integrate together. The original speaker is called 'Kord Tornado', i believe that they were studio styel mid-field monitors from the late 80's (i guess). They came with the Volt BM220 'DS' version and a Scan Speak D2008/8512, it was 'up graded' by the previous owner to a Scan Speak D2905/9300. I dont think that the crossover has been changed. The enclosure seems to be around 32 Litres, and using the BM220.8 as a model, tuned to 36Hz with F3-35Hz. Looking around, it seems that the SS D2905/9300 has been paired with the Volt BM220.8 in the Wilmslow Audio HSM and the Solen HSM kits. Would these crossovers be a better starting point? Does anyone know the differences between the older BM220DS model and the newer BM220.8 model? Thanks, Rob Last edited by inrank; 20th January 2011 at 07:10 PM. |
#2 |
Here is a picture of the crossover, cant seem to work out the schematic
The bottom shows the connections (rotated and flipped) I believe that it shows the tweeter out of phase? so should it be wired at the tweeter in or out of phase? Last edited by inrank; 22nd January 2011 at 03:51 PM. |
#3 |
Hi Rob. It's a type 2Way 2nd order xover with a resistor before C1 on tweeter. I don't know what is after C1 (box/rele? look alike, can't see). The phase is very much related with distance in the front baffle between drivers and xover frequency. It can be one or the other. Sometime ago we were checking this same problem in another manufacturer (ATC?) with both connections or different setups.
#4 |
C1 = 2u2 (2.2uf??)
L1/L2 = not marked C2 = 2x 2u2 (2.2uf??) R = 2r2 (2.2 Ohms??) After C1 it goes to the coil and 2x 3.3uf capacitors. On the crossover, the right hand side is the mid/bass and the left is the tweeter I was asking about the phase as when the tweeter was changed, not sure if the has tweeter polarity has been changed, would this cause the midrange suck out? Last edited by inrank; 23rd January 2011 at 02:01 PM. |
#5 |
Rule of thumb: If the xover is second order hp & lp the tweeter needs to be inverted.
#6 |
#7 | ||
Yes, 3rd Order on tweeter. (I can see now the inductor/cooper on the side of the double caps, that looked like a "box")
Your xover should be fine, with inverted phase on tweeter. Quote:
#8 | |
#9 |
Ah ok, just had a look at the other crossover, the two 3.3uf have been replaced with a single 6.0mfd cap. Will that make a huge difference?
The main problem is that with the ATC's (xover @ 2.8Khz) you could hear voices coming out of the mid/bass driver which gave vocals weight, on these all the vocals come out of the tweeter, and looking on the web, the xover seems to be in the simmilar area (2.5-3.0Khz) using the capacitor values on a second order network. Hence the lack of integration between the drivers, and the lower midrange suck out. Last edited by inrank; 23rd January 2011 at 04:28 PM. |
#10 | ||
If you want to go trough the pain change xovers or test new implementations from scratch. We have: Volt BM220.8 (Volt BM220 'DS' version is used, is it the same/similar?). Scan Speak D2905/9300 https://www.madisound.com/store/prod...roducts_id=910 You go to this xover that is used with similar drivers Design of the Month Or if you start with a new (different) approach. This xover (second order) also might work but is for another, not very different driver ScanSpeak 18W/8545 SpeakerBuilding.com - Making of M1 - Print Good luck Rob. I would like to add this as reference, when people ask if they should use sealed or BR. http://www.pinkfishmedia.net/forum/a...p/t-26358.html Last edited by Inductor; 24th January 2011 at 12:17 AM. Reason: pic.hsmxover from www.solen.ca |
| ScanSpeak D2905/9300 Tweeter Pair - New-ish! | HampyCapper | Swap Meet | 2 | 27th May 2010 04:01 PM |
| Man vs. tornado - | tomtt | The Lounge | 0 | 26th March 2009 09:38 PM |
| Trade pair of d2905-9300 for one 18w8545K-00 | i4gotmyid | Swap Meet | 1 | 12th August 2008 09:28 AM |
| Volt BM220DS (older model) or BM220.8 Impedance @ 3000hz ? | dynoPort | Multi-Way | 3 | 31st May 2007 07:30 AM |
| Help...I need a crossover for SS 18W/8545 and SS D2905/9300 | softman | Multi-Way | 8 | 19th November 2002 07:11 PM |
| Page generated in 0.11957 seconds (77.10% PHP - 22.90% MySQL) with 11 queries |
