Old 20th January 2011, 04:09 PM   #1
mondogenerator's Avatar
Default Is this driver suitable for MLTL?
i have a pair of Audax drivers im thinking of trying to design an MLTL for, and i just wanted to pick the brains of anyone who can help.
ts parameters:
Fs 64
vas 4.7 litres
Qts 0.49
Qms 2.16
Qes 0.63
BL 4 NA
Sd 50.5 cm²
im considering 'trying' to make a bookshelf type, i.e. small as possible, and perhaps folded as well. I was just slightly unsure whether the Qts of 0.49 was too high for an MLTL; or conversely whether the fairly high Q would be ideal to squeeze some more LF out of this driver.
thanks for taking the time to read, and for any advice in advance.
Its a case of Perception:You never stop being a 'Noob' (a term banned on many social gaming sites), Ego is the Thing that tells Us otherwise.
Old 20th January 2011, 04:17 PM   #2
unless im mistaken there are no alignment table posted for the MLTL, as there are for the TQWP. UNfortunately, mathcad isnt exactly my forte...
Old 20th January 2011, 04:45 PM   #3
pkitt is offline pkitt  United States
Give me the values for Re and Le and I'll see what I can model for you in an ML-TL. How "small" must this cabinet be? Do you already have in mind height and width?
Paul
ts parameters:
Fs 64
vas 4.7 litres
Qts 0.49
Qms 2.16
Qes 0.63
BL 4 NA
Sd 50.5 cm²
Old 20th January 2011, 06:25 PM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Default Guesswork?
Why do you hide the driver Brand identification numbers? Are your T/S # measured or the manufacturers?
need some classic tl advice
See the consequence when using your data:first picture:
Wild guess: See the second picture.
b
Old 21st January 2011, 08:11 AM   #5
Default haha you guys are ace!
ah yes a slight oversight on my part i see. specs are manufacturers data, and ive seen some on both zaph and hennessys' sites, which maybe are more accurate.
quoted VC inductance is 0.45mH
DCR 6Ohm
LOL @ Bjorno: yes easy to guess really! Ive had them lying around for ages. they could be a rapid build easy sealed or vented design, but im toying with other ideas
I have seen some things with small fr drivers in 'bookshelf' MLTLs which looked ok, but havent been able to model one. Abandoned the idea of a TQWP a while ago, due to size.
I figured, (i think), in the most basic way; the way i designed my last QWP, i ended up using a 20:1 taper. i did model it further, with higher ratios, but i settled at 20:1 for the minimum port area i was prepared to accept. essentially youre doing the same as early reflex designs that used just a simple port hole and a large Vb. PKITT i think you helped me with that project! So thanks again for the help.
size wise....hmm.
depth im not bothered about really, so HxWxD id say:
12"- 15" x 6"- 8" x 12"- 15"
ballpark ideas really. it will either be going with an TM025F1 or tangband W2-800SL and xovers to suit whichever. when i figure out a tapped horn on Hornresp im going to see what i can model in a similar size crossed to the tangband around 300Hz. it may be a ridiculous idea though...
i envision maybe a folded MLTL, 2,3, or 4 folds, but with a taper. However, with a net taper of zero over the first 2 or 3 sections, depending on how many folds may suit. eg in 3 fold design, 3:1 in the 1st section, 1:3 in the 2nd, and 3:1 again in the last. perhaps even just a straight untapered last section, im unsure. just an idea, no idea if its a good one! lowest vent area with that driver? maybe 2 in²?
Old 21st January 2011, 08:20 AM   #6
Hennessy quotes some of the AP100ZO ts parameters after 30 hours run in. these have had loads of run in, but i havent gotten around to measuring anything myself yet. (cheap DMM, and with a desire for accuracy, the necessary calibration curve beforehand.........)
Fs = 60.9
Qms = 1.60
Qes = 0.63
Qts = 0.45
Vas = 4.36
Old 21st January 2011, 06:54 PM   #7
GM is offline GM  United States
GM's Avatar
Well, a T/S max flat alignment is ~ 6.3 L/55 Hz Fb, so converting it to a MLTL nets us a slightly lower 51-52 Hz Fb due to 1/4 WL vent loading (all dims approximate):
L = 27.54"
WxD = 13.96"^2
zdriver = 9.256"
zport = 26"
dport = 0.75" dia
Lport = 1"
Fold into an inverted 'U', which puts the driver up near the top and the vent down near the bottom and since this is a max flat alignment you may want to try longer vents to roll it off if too 'boomy'. That or use more damping. Sim is minimally damped.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st January 2011, 08:33 PM   #8
thanks GM, thats quite compact, i am, to be honest, surprised. theres only one thing that would concern me a little, the vent area. assuming i can up the vent area and length appropriately and in a similar way to reflex ports, then perhaps ill up the vent area a little.
cheers for the input, i think this project may definitely be worth persueing
Old 21st January 2011, 09:16 PM   #9
GM's Avatar
You're welcome!
With a 30 W rating and TL vent loading, the vent doesn't have to be as big as in a simple reflex or ducted port. Regardless, at a glance it looks like there's not enough room to increase vent length much, so tuning any lower won't be an option if you start with a bigger/longer one. All you can do then is add stuffing which at some point may start 'muffling' the driver's HF output.
GM
Old 21st January 2011, 09:55 PM   #10
true enough. ive had these drivers running fairly loud sealed and vented, and they really probably cant tolerate much more than 10 watts in either alignment, and the mids suffer a little nasal sound when driven hard, so in all likelihood, and when i think about how im going to be using the speakers, the port area probably isnt a huge concern. bonus is i can use 1" timber for the panel and just drill the port with a ¾" spade bit.
This driver suitable for OB? Fast1one Subwoofers 9 25th April 2011 05:29 AM
Eclosure suitable for this driver. Aucosticraft Subwoofers 8 11th June 2010 03:41 AM
MLTL driver/port placement, floor reinforcement etc... maxro Full Range 26 3rd July 2008 01:30 PM
MLTL reverse driver/port location thinkbad Full Range 1 4th April 2006 08:57 AM
Suitable driver for Ultralinear? arnoldc Tubes / Valves 10 11th November 2003 10:23 PM
Page generated in 0.11983 seconds (84.10% PHP - 15.90% MySQL) with 11 queries
