Hi, guy´s
One year ago I finished to build my first 2 way-speakers with XOP with fc=3Khz. I used a titanium tweeter which It reaches 2Khz. Presenty, I´m building an amplifier and, in the future, a XOA. Then I´m thinking in bi-amp. For 2 way-speakers with the same tweeter that I described before, what is the optimal cut frecuency if I use a XOA? Could I use the same (3Khz)? I was reading the article about bi-amp in Elliot Sound, but I´m little confused, `cause He uses 3 way-speakers. Any advice will be appreciated Thanks, Marcelo.
There is no emotion; there is peace.There is no ignorance; there is knowledge.There is no passion; there is serenity.There is no death; there is the Force. |
#2 |
Normally two way speakers would be bi-amped to the sub or subs at a frequency in the bottom range of the lower part of the two-way.
Usually, if you are using line level crossovers ( after the pre amp but before the power amps) up in the 3k range, that system is being tri-amped with a pair of amps for each range of lows, mids and highs - Think about it along those lines and that will probably put you on track Later Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
#3 |
Thank for your answer.
![]() I don´t have a sub and I don´t think to build/buy one ´cause I don´t have space and I´m very please with the bass response of my speakers. I build a 2 way speakers with a midwoofer of 8"... Then...3Khz ??? Marcelo
#4 |
2 Way system with 8" to 3Khz. Consider the transfer-funksjon in your speaker filter before making line level filter, then it should bee possible to make near ore equal to your 'ideal response' (u know youre speaker data's i supose?)
#5 | |
Yes, I know the TS parametes of my woofer, `cause I have to measure them to design the box (They are not Vifa or ScanSpeak, they are made for a argentinian company and, in the beginnins, I didn`t trust very much in them until I visited the factory.... Anyway, I don`t have the data here, rigth now. Tomorrow I`ll show a picture of mi speakers, the TS and the filter that I buid. See you Marcelo
#6 |
The T/S parameters aren't going to be of any help in determining your crossover to the tweeter. You'll need a response curve. An impedance curve wouldn't hurt either.
#7 |
Well, I post all the information that I have:
Woofer 8": SLP 90db/80W/8ohms Qms 2.84 Qes 0.82 Qts 0.64 Fs 46Hz Vas 49 I measured all this values. I found very good response from 80 Hz to 3.5k. I used second order Bessel filter with: Fc 2500hz C 4.7uF L 900mHy Zobel Re 6.8 ohms and C 10uF Tweeter: 3.75" Aluminum Bullet Horn with 1" Super Tweeter SPL: 99dB/120W/4 Ohms Frequency Response: 1.5k-25kHz I use second order Bessel Filter (same values as above) and L-pad with R1 5.6 ohms R2 8 ohms I had the frecuency response in my PC, but unfortunatly I had a problem and It dissapeared... Anyway, I know that this speakers are more suitable for car audio use,but It`s the better that I can find here. Importation It`s almost imposible, `cause the economical situation`s of my country (2 years ago I earn u$2000, presently only u$700...devaluation). I have a pair of Audax Tweeters (AW01E01), but I`m going to use them with a 6" midwoofer. Well, Dou you think that I can use 3K for XOA? Or It will be better if I change the configuration to 3 way system? Any advice will be appreciated. Thanks, Marcelo
#8 |
If you are currently happy with your passive 3k XO i'd start there. An active XO is doing the same job as the passive but before the amps instead of after.
Because of this they are much easier to play around with. i have a set of active XO links on my web page which will give you more reading. http://www.t-linespeakers.org/linx/xolinks.html dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
Higo,
Theorically, the three ways seems to be the way for a fully optimized active system. I am in the same stage like you are, and I'm decided to build also a two way active crossed over in the same range of frequency (but 6" woofer). Most of the advantages of the biamping would appear, i hope, but seems to be that the 3ways are the way here. Which xover do you plan?
What is beyond the speaker? |
#10 |
95% of the advantages of bi-amping to a woofer around 100Hz, give or take, do not translate to bi-amping a mid to tweeter.
Unless extenuating circumstances prevail, a passive network is the most practical and cheapest way to go. |
| 5W Zen for biamp tweeter | Kanga | Pass Labs | 16 | 2nd February 2010 11:58 PM |
| acoustst 2+1 biamp? | Williams Audio | Planars & Exotics | 8 | 30th July 2007 06:42 PM |
| DIY Biamp project | docz | Full Range | 1 | 25th November 2004 08:50 PM |
| To Biamp or not to Biamp, that is the question??????? | Apogee | Pass Labs | 70 | 12th July 2002 01:34 AM |
| biamp with active x-over | Fossil | Solid State | 9 | 10th October 2001 03:10 AM |
| Page generated in 0.13452 seconds (81.20% PHP - 18.80% MySQL) with 11 queries |
