#11 | |
Unless well planned and speakers well picked, a good passive XO is one of the hardest things to get right, and can present a really ugly load to the amplifier. With a complex passive & the low cost of some decent amps we are seeing, active can actually be cheaper in some cases. I heartily recommend going active all the way. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 |
Cheaper my foot. The extra amp needed makes it more expensive and that doesn't count the crossover.
And it's just as hard to come up with the correct transfer functions with an active network as with a passive. The load presented by a passive crossover is not that ugly. I only use active for the high frequency crossover if I need to level match, tailor the curves in an unusual way or need a differential circuit. |
#13 | ||
[QUOTEThe load presented by a passive crossover is not that ugly.[/QUOTE] Any crossover is uglier than directly into the speaker. Unless you are using something like a simple cap in series with a well-behaved tweeter, i'd consider active the way to go, and even then if quality is your main concern. dave
#14 | |
Raka:
I`m planning to use second order Butterworth in Sallen - Key topology. According to Rod Elliot article about biamp and your comments I think that I have to change my speakers. I mean rebuild them from 2 ways to 3 ways. I have to change the box or do you think that I can use the same? I never design a 3 ways system... Quote:
BR. Marcelo
There is no emotion; there is peace.There is no ignorance; there is knowledge.There is no passion; there is serenity.There is no death; there is the Force. |
#15 |
I think we know start system design... triamp and aktive all the way. Personaly i belive IC amps in an fully aktive design beats amplifier and passive x-over speaker's.
The main reason i think is that speaker element's parameter varies with motion and is therfore a komplex load and have more than frequensy as a variabel to the filter. And that an amplifier is more suited for that job than any passive filter output ever can cope with. |
#16 |
i think that there are few things which benefit sound more than bi-amping or tri-amping. i have bi-amped Linn Kelidh's driven by a Linn Majik and a Linn Power Amp -- I was able to audition both the passive xovr version of the kelidh's and the active xovr version before I decided to go with the biamped version -- I also biamped a set of the KEF reflex speakers (KEFB139/B110 and Audax Tweeter) -- now disused collecting dust in the basement/laboratory. The quad GC I was building was to use active XO but I haven't gotten around to finishing it.
Speaking of designing XOVR's I again refresh the list with the link to the beta at Analog Devices: http://www.analog.com/Analog_Root/st...er/filter.html This is much more comprehensive than the design tool at Texas Instruments. |
#17 | |
A shame to have those wasting away... you can send them to me ![]() More seriously, people are looking for those all the time... you'd fetch 200-300 on eBay for the B139s & B110s. dave
#18 |
Made up a stat-var filter. Also made lovpas(30-600) and highpas (600-10K)freq adjustable. Then bass gain and mid Q adjustable.
At the end i figured it vise to add inverters at the same time. Then phase switch or balanced output is possible. Only one channel without power suply shown: |
#19 |
the state variable filter lends itself easily to use with the digital potentiometers from Analog Devices, Dallas etc. In fact, Analog Devices has one such circuit using the AD7528 Dual DAC:
http://www.analog.com/UploadedFiles/...68AD7528_b.pdf |
| 5W Zen for biamp tweeter | Kanga | Pass Labs | 16 | 2nd February 2010 11:58 PM |
| acoustst 2+1 biamp? | Williams Audio | Planars & Exotics | 8 | 30th July 2007 06:42 PM |
| DIY Biamp project | docz | Full Range | 1 | 25th November 2004 08:50 PM |
| To Biamp or not to Biamp, that is the question??????? | Apogee | Pass Labs | 70 | 12th July 2002 01:34 AM |
| biamp with active x-over | Fossil | Solid State | 9 | 10th October 2001 03:10 AM |
| Page generated in 0.12339 seconds (80.30% PHP - 19.70% MySQL) with 11 queries |
