Hi All,
I just created a new spreadsheet for traditional loudspeaker design.
Loudspeaker Spreadsheet (no macros)
When I am trying to learn something I find that it helps to design software or, in this case worksheets, to understand as much as I can about the subject. I searched the web and books to gather most of the formulae but the dimensions are my own.
This spreadsheet calculates HxWxD dimensions using Phi and provides several different vented box solutions and port lengths as well as custom volume solutions. You can also plot the various solutions' frequency response.
If you have the time I would love to hear from fellow DIYers about the spreadsheet and any and all comments or suggestions would be well appreciated.
If you are new to this, like me, I hope you find the spreadsheet useful.
Thanks,
Gregory
Thanks,
Gregory
Vent Diameter
Hi Ralph,
Thanks for you kind words.
The vent length changes but the diameter does not. Should it?
My impression was that the reason to add more than 1 port/vent is to increase the port area to reduce turbulance at the openings and thus you would usually keep the same diameter.
Gregory
Hi Ralph,
Gregory
Nice beginner level sheet. a few comments:
The proper formula for sound speed is 20.06*sqrt(T+273)
Your X's for plotting are locked.
It would be more readable if you removed some of the unnecessary precision in the calculations. I doubt anyone needs to see precision past the 2nd decimal place for most calcs.
Ron E said:Nice beginner level sheet. a few comments:
Thanks. I used the less than proper speed
from the url below and the proper formula was starring me in the face.
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/souspe3.html#c1
I have fixed these, thanks again, and also fixed the speed to proper.
I made them 4 and it does look less intimidating.It would be more readable if you removed some of the unnecessary precision in the calculations. I doubt anyone needs to see precision past the 2nd decimal place for most calcs.
Thanks again Ron, great comments!
I don't have the formula for peak velocity only for the minimum diameter:
39.97.((411.25.Vd)/Fb^0.5)^0.5
folowing the optimum lenght:
((1.463.10^7.R^2)/(fb^2.Vb))-1.463.R
Vb is in cm^3
Perhaps you should contact kristian ougaard, he design unibox and has a airspeed graph inserted.
Ralph
Vb is in cm^3
Ralph
- New Vented/Closed Spreadsheet
