Hi
Sorry about the bad quality of the pictures , but should give you an idea anyway
http://www.triodejan.dk/Betamods1.jpg
Shows the 3 point threadspider
http://www.triodejan.dk/Betamods2.jpg
Shows the coated cone , and new dustcap
http://www.triodejan.dk/Betamods3.jpg
Shows the extra magnet attached
http://www.triodejan.dk/Betamods4.jpg
Shows the thread arrangement again
http://www.triodejan.dk/beta101.jpg
Shows me and the ready horns(not the final paint!)
Will post better pictures when I can
Best regards
Goofey
Best regards
Goofey
Goofey, thanks for the pics.
I am looking for the least compromises in a single driver speaker myself so I hope you don't mind some questions.
Why did you chose the Coral Beta 10 in the first place?
Were you trying to correct a specific problem or just achieve a general improvement?
What were the results of listening to the changes?
What have you done other than the spider?
What is the driver coated with?
Can you list your system?
Thanks Again
Tom
Thanks Again
Tom
Hi Tom!
Please ask away!
Because I think that it was the best fullranger ever!
Both , see below.
Everything got better , deeper bass , MUCH flatter response , extremely flat from 25HZ to 12KHZ(mounted in horns)
Free sounding , great imaging , I thought I will miss a tweeter , but no!
The modded Corals are 102dB/1W in horns , and in the hole area from 25HZ to 12KHZ , yes it has been meassured!!
Extra magnet , phaseplug removed , new 1/3 tabletennisdustcap attached , surrounds coated with vaseline , voicecoils replaced with some from Beta8's , gives longer travel , but still 8 Ohm's!
Something called Isopunkt , you use it for repairing roofingfelt , and it MUST be the Zylen based type , just 1 coat on the front of cone.
For the moment I use an Parafeed 2A3 amp with the horns.
Own design.
Great combo
Best Regards Goofey
Please ask away!
Both , see below.
Own design.
Great combo
Best Regards Goofey
