Old 16th January 2011, 08:26 PM   #1
Smile Sealed Tymphany MTM's
Hello,
I bought 2 pairs of these Tymphany TPY04W16S0086 16 ohm woofers. They look very similar to Vifa PL11 series drivers. They are, I believe, OEM for Sonus Faber.
Tymphany TPY04W16S0086 5" Woofer 16 Ohm | Parts-Express.com
Being 16 ohm they are begging to be ran in parallel in a MTM setup. I am thinking sealed enclosure(s) Plus a real woofer.
Do you speaker builders have any thoughts? In the MTM arrangement does each M get its’ own separated volume in the enclosure or do they both share the larger single volume?
DT
All just for fun!
Old 16th January 2011, 08:40 PM   #2
Moondog55's Avatar
Oh heck and me with no money to spend/
my first thoughts were WMTMW with a sub on the bottom.
Sealed mid with a single compartment for both mids and a really good tweeter
Look like PL line to me, I don't like the soft poly dust-cap
Buy em and put them away until you can get some nice 8inch woofers to match
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 19th February 2012, 06:04 PM   #3
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
I started, but, then decided I need to redo the baffle to offset the tweeter...
Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com - critofur's Album: Tiny MTMs
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 19th February 2012, 06:35 PM   #4
Two in MTM arrangement could be used as the mids in a 3 way.
Alternatively they would also be good for small TMM or MTM
2 or 2.5 way satellites to be used with a subs in an AV system.
Vas is tiny, due to the high Fs which dictates for AV a fairly
high x/o point and probably stereo subs for the best results.
rgds, sreten.
SPL: 84dB/1W/1m is really playing with numbers, its not stated
as efficiency or sensitivity. They are either 81dB/2.83V/1m or
84dB/2.83V/1m, and it really should be made clear what it is.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Tymphany LAT700 in an OB rastanearian Subwoofers 6 6th September 2010 06:41 PM
Tymphany LAT Tenson Multi-Way 23 27th April 2008 11:38 PM
Input on some MTM's black300zx Multi-Way 12 12th January 2007 10:03 PM
MTM's using the Vifa P17WJ Nisbeth Multi-Way 12 5th November 2004 03:31 PM
Dayton III MTM's cj.9 Multi-Way 4 1st January 2003 04:16 PM
Page generated in 0.07510 seconds (75.11% PHP - 24.89% MySQL) with 10 queries
