does anyone used it ?
please suggest me paramenters to load it in reflex loading. thank you |
#2 |
AKUSTYK says:
30 l netto BR port 27 x 7 cm 33Hz - 6dB Madisound: 34 l BR port 20.3 x 7.6 cm F3 39 Hz |
#3 |
#4 |
These results were modelled by BassBoxPro 6.
For max flat response, use 20L with dia. 60mm, length = 340mm port. F3 = 48Hz For standard tuning : Use 30L, dia 60mm, length = 300mm. F3 = 47Hz, usable to 30Hz For max bass extension, Use 40L, dia 60mm, length = 285mm, F3 = 53Hz. Usable to 25Hz I'd go for 34 to 40L for very deep bass and reasonable group delay. 15 ms @ 25Hz
Sand till the end of time |
#5 |
thank you guys
#6 |
I am considering this driver for a 3 way passive XO construction in its own 20L cabinet.
What would be the effect of using a Passive Radiator instead of a reflex tube? What would be the effect of using a variovent instead of a tube?
Regards. Michael |
| 2-Ways speakers for 22W per channel amplifier | silcerino | Multi-Way | 4 | 21st December 2010 11:15 AM |
| PL36 PP Amplifier 22W Full construction details | mario2005 | Tubes / Valves | 13 | 19th October 2009 05:15 PM |
| 22W/4851T Revelator 8" woofer an upgrade for 21w-8554? | Daveis | Multi-Way | 0 | 9th October 2007 02:14 AM |
| 22W OTL amplifier circuit | DarkHorse | Solid State | 20 | 4th February 2005 07:49 PM |
| Scan Speak 22W/8851T00 | Antonio | Multi-Way | 0 | 3rd May 2004 04:57 PM |
| Page generated in 0.07649 seconds (77.13% PHP - 22.87% MySQL) with 10 queries |
