Old 15th January 2011, 11:02 AM   #1
Formerly Thanh1973
Melon Head's Avatar
Default What do people think about this open baffle speaker?
What do you guys think about cloning this speaker?
6moons audio reviews: Yamamoto SoundCraft YS-500
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need."
Old 15th January 2011, 09:10 PM   #2
fmena is offline fmena  Canada
Default Looks nice however....
it seems that it only goes to 18K, so maybe a super tweeter would be nice to add? It kind of reminds me of 4 Pi Speakers from the USA (Pi Speakers - unmatched quality and state-of-the-art performance) in that it they also use Eminence and B&C components in their designs, but Yamamoto has an open baffle configuration instead.
FM
Cheers
FM
Old 15th January 2011, 10:22 PM   #3
Formerly Thanh1973
Melon Head's Avatar
Specifically, I was wondering what people think about using the low QTS deltalite woofer in an open baffle arrangement I know Troels Gravesen also uses this woofer and prefers it over Eminence Alpha. Most people recommend QTS around 0.7 but the deltalite has QTS=0.38
What is necessary to effectively use low QTS woofers in open baffle speakers?
Old 15th January 2011, 10:28 PM   #4
a.wayne is offline a.wayne  United States
a.wayne's Avatar
I guess some do get bored ....
Old 15th January 2011, 10:31 PM   #5
ScottG is offline ScottG  United States
1. *Large* baffle, or
2. Heavy resistance to lower motor strength and raise Qe, or
3. Equilization in the filter, either actively or passively.. or an eq. before the filter, or
4. Transition to another source (or sources) of pressure to sum flat. (..like an active sub used as a woofer with a broad and "shallow" low pass filter).
..usually a combination of 1, 3, and 4.
perspective is everything
Old 15th January 2011, 10:45 PM   #6
Formerly Thanh1973
Melon Head's Avatar
Can anyone show a modelled frequency response of two woofers QTS=0.38 vs QTS=0.7-1.0 on a baffle width of about 20" with wings of acceptable depth.
Old 15th January 2011, 11:25 PM   #7
49 - for the 16th time
c2cthomas's Avatar
Couldn't you just leave the back off of an EconoWave?
Well - I would need to find a price for "an Ebony-encased polypropylene capacitor sourced from the American Dearborn Co." I'm betting that it isn't cheap........ Hmmmmmmm............... does PE have a suitable sub for that cap???
BTW - I like the speaker!!! It takes me back to the days of an old stereo console my parents owned back in the mid '60's. It had a stereo tube powered amplifier - probably about 25 watts per (maybe less) a record "changer" which had a huge plastic arm and most likely tracked at around 1000 grams
and an AM/FM radio. I think it might have been a 3 way system with 12 inch woofers - 3 or 4 inch mid's and I don't know if it even had tweeters!! The back was open - and it sounded as sweet as the big 'ol juke-box down at the soda fountain.
The attached photo is off of the 'net - and not an actual photo of our old stereo - but you get the idea......
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 16th January 2011, 12:30 AM   #8
Pano is offline Pano  United States
Pano's Avatar
Usually a very large inductor. Anywhere from 12 to 20mH. This fights the rising response of the low Qts woofer on an open baffle. It can work quite well. Trade off is loss of efficiency.
Active EQ can do the same thing, but you still lose efficiency.
Take the Speaker Voltage Test!
Old 16th January 2011, 01:03 AM   #9
Formerly Thanh1973
Melon Head's Avatar
I would love to see a frequency plot before equalising.
How much efficiency is lost through passive equalising?
If it is no more than 6dB than I might be in business.
Old 16th January 2011, 02:45 AM   #10
Pano's Avatar
It can be 10dB depending on baffle size, Qts and other things. There is no free lunch.
My first Open Baffle Speaker audiojoy Multi-Way 197 2nd September 2010 10:29 PM
Open Baffle with Guitar Speaker davidallancole Full Range 5 28th March 2007 07:47 PM
a speaker project : open baffle then_dude Multi-Way 0 28th March 2005 05:33 PM
Page generated in 0.13095 seconds (76.86% PHP - 23.14% MySQL) with 11 queries
