I hope someone can explain this as i certainly cannot. Two Sollen capacitors in a second order crossover have both gone open circuit but the Scanspeak tweeters are fine. Same failure in both speakers. Caps are rated at 250v and 400v DC. Really curious how two caps in series both go open circuit.
#2 | |
For X-O duty I much prefer the Clarity SA over the Solen they just seem to sound more detailed/open without becoming obnoxious and they are in about the same price range.
www.kta-hifi.net |
#3 |
Hi Kevin. Thanks for your explanation. The Solens are indeed the ones with the red epoxy. They belong to the crossover of a commercial speaker, i am not normally that cheap
#4 |
Yes, unfortunately that is exactly what they do, and the eventual failure rate seems to be very close to 100%. The only reliable solution is to replace them with something else..
www.kta-hifi.net |
#5 |
...perhaps bad internal connections ("foil" to leads?)
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#6 |
Actually these are metalized film types and apparently it is the chemistry/process of the metalization that is failing not the end terminations. This problem has been widely discussed here and elsewhere - the problem manifests itself in certain series of Solen caps from 20 or more years ago. There have been reports of newer ones infrequently failing as well - I have had at least one mid/late 1990s fail - cause undetermined.
I use them only in power supply applications IMHO they don't perform well enough sonically for use anywhere else.
www.kta-hifi.net |
#7 |
wow!
i knew i was better off avoiding boutique caps such as solens, and sticking to vishay polyesters, and bog standard HV PP caps.....even building capacitive dividers at work i have never had a cap go o/c, or even s/c..........
Its a case of Perception:You never stop being a 'Noob' (a term banned on many social gaming sites), Ego is the Thing that tells Us otherwise. |
#8 | |
I do specifically recommend the Clarity SA series for X-0 use and that's definitely a "boutique" cap in some quarters. New Vishay film caps are good quality, and actually cost a good deal more around here than comparable Solens, but are widely available surplus at good prices. I use them too.
www.kta-hifi.net |
| amplifier failure modes | sakis | Solid State | 8 | 7th August 2010 06:08 PM |
| OPT failure modes | jeff mai | Tubes / Valves | 3 | 29th March 2005 11:59 AM |
| Gain Clone failure modes - Peter, et al? | mgreene | Chip Amps | 10 | 20th April 2004 05:43 PM |
| Transformer failure modes | Zodiac | Solid State | 9 | 25th October 2003 10:35 AM |
| Laser Pickup Failure Modes ? | mrfeedback | Digital Source | 6 | 1st February 2003 04:59 PM |
| Page generated in 0.10645 seconds (74.48% PHP - 25.52% MySQL) with 10 queries |
