Old 13th January 2011, 07:11 AM   #1
ttan98 is offline ttan98  Australia
Default Designing a dipole in a sealed enclosure
I like to design a dipole with 2 full range drivers(each driver has 4ohm) mounted back to back and wired them in series and out of phase. Both of the drivers are mounted on a sealed enclosure. I think that would make the setup a dipole instead of a bipole.
If I have only a single driver on a sealed enclosure the capacity is about 4litre to give me a -3dB of about 90Hz. If I increase to 2 drivers do I double the capacity or still remain at 4litre to give me the same bass roll off.
Anyone who has experience in this area please response.
Old 13th January 2011, 07:17 AM   #2
will you be using your dipoles with a sub woofer??
Old 13th January 2011, 07:50 AM   #3
Yes
Old 13th January 2011, 07:59 AM   #4
CLS is offline CLS  Taiwan
In such case, the air in the box is not compressed/stretched as the cone motion as in normal sealed boxes. Some air flow would be there among the baskets... etc, locally. The volume may have some effect in being a load (as mass) on the cones, thus changing the fs of the system somewhat. But it's never the way like a normal sealed box.
The frequency response is still dominated by the system Q and dipole loss.
Old 13th January 2011, 08:32 AM   #5
frugal-phile(tm)
planet10's Avatar
If you wire as a bipole you will get the same bass. If you wire as a dipole (with or without separate cabs) you will get no bass.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th January 2011, 10:45 AM   #6
Pan is offline Pan  Sweden
dave
If the same volume is used for two drivers instead of one the response will change. The response will be as if each driver was mounted in 2 litres.
/Peter
Old 13th January 2011, 11:52 PM   #7
frugal-phile(tm)
planet10's Avatar
2 liters per driver or 4, because the drivers are wired out of phase there will be no bass.
dave
Old 30th January 2011, 03:39 PM   #8
Dave, if you put one or two drivers in the same box volume you will get different results, both in frequency response and various kinds of distortion.
If you wire the drivers in opposite polarity you get a dipole bass.
Saying that you get the same bass in case one and no bass in case two is simply wrong.
/Peter
Old 31st January 2011, 12:42 AM   #9
Peter, consider how big a speaker would have to be for a dipole effect.
Even an 8 litre cabinet will be a point source at low frequencies. The air won't know there are two drivers if you wire them out of phase, it'll just think you're using a very thick cone. Thus, the effect will be nearly the same as one driver in free air - no bass.
Otherwise, yes, if you use two drivers you need to double the size of the box because you have twice the cone area and that doubles the Vas.
Old 31st January 2011, 07:05 AM   #10
Patrick Bateman's Avatar
If you skip the box you'll get more efficiency at certain frequencies, since there will be points in the frequency spectrum where the radiation from the rear of the cone will sum in phase with the radiation from the front of the cone. Check out "The Edge" from Tolvan. (Google it)
suggestions for designing OB/dipole using AN's radianceaudio Multi-Way 3 14th March 2010 06:52 AM
Transient Response: Sealed v Dipole rick57 Multi-Way 4 12th December 2006 05:26 AM
Designing a fullrange dipole? Kensai Full Range 10 6th January 2006 03:49 PM
help designing an enclosure felzi Subwoofers 7 5th July 2005 05:20 AM
Designing a Linkwitz Transform sealed sub BAM Subwoofers 1 28th April 2002 11:32 PM
Page generated in 0.10078 seconds (86.35% PHP - 13.65% MySQL) with 10 queries
