The driver is the goldwood delmar series 12" 8R driver here ... Goldwood GW-12PC-8 12" Heavy Duty Woofer 8 Ohm | Parts-Express.com
I used bassbox pro 6 , used the TS params from GOLDWOOD as the parts- express parameters are freakin' wrong (Qms - Vas was way off). This excellent driver from goldwood is very HD , with a cast frame but 1/2 the price of a dayton. The params are : Fs = 32hz Qms = 3.83 Qes =.56 Qts = .49 Vas = 85L (2.9sq.ft.) I let BB6 pro do the calculations for a 100L ported enclosure with a 76mm port size , output (below 1). My question is about box size ... bassbox says the driver can be used for either sealed or ported , it suggests a rather large 130L box witch gives a f3 of 26hz. I reduced Vb to 100L and even 85L and my f3 rises to 35-38hz. Is this the only tradeoff ?? Also , can I change the tuning of Fb to compensate for a smaller box ?? Any help for a newbie would be appreciated , I don't want to build the boxes twice. ![]() PS. Attachment below is with the 100L alignment. OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ |
#2 |
Bump... no answers..
#3 |
A good rule of thumb when looking at drivers for vented box is that the Qts should be below .45. Above that and the driver is more suitable for sealed.
As for the results that Bassbox is giving you, there would be a peaked response when you reduce the box size. You ideally want flat response. |
| who makes 18" x 12" x horn 3-w box??? | mastadon | Full Range | 2 | 29th October 2009 08:31 PM |
| Vented box volume needed for Peerless 830884 8" | duffsag2468 | Multi-Way | 3 | 22nd July 2008 10:43 AM |
| replacing 12" sub in box with back speaker mounted 6" subs | aussiebuddha | Car Audio | 7 | 14th October 2006 08:26 PM |
| JL audio W3 Dual Voice 12" sub box question? | Trickflowing | Subwoofers | 8 | 2nd December 2005 03:06 AM |
| Vented box design question | thylantyr | Multi-Way | 4 | 1st October 2002 07:01 AM |
| Page generated in 0.06695 seconds (75.64% PHP - 24.36% MySQL) with 11 queries |
