Hy, i am tring to make a 3 way crossover but it doesn`t work and i dont know why, please help me. When the volume si down all it`s fine but when i turn up it the mid and the twiter start to make a buzz sound special when it plays the "a"sounds .
The speakers are Monacor - Romania Monacor - Romania and about the bass speaker i don`t know anything but it works fine, it has 10" The crossower 800Hz/5000Hz ![]() Uploaded with ImageShack.us Last edited by Matei Alin; 11th January 2011 at 01:40 PM. |
#2 |
can the crossover handle the power? Have you used parts that are sufficiently rated? What kinda power are you pushing through?
#3 |
50w, i think it can handle the power. Maybe the crossower is incomplete? (a l-pad or something like this)
Last edited by Pano; 11th January 2011 at 03:04 PM. Reason: image resized for forum |
#4 |
Usually there is some sort of resistor ot L-Pad on the tweeter to get it to match the level of the other sections. There may also be one on the midrange. Your mid and tweeter are close are close in sensitivity, but the tweeter should have some pad.
How does the tonal balance sound? Is the bass section weak compared to the others? Also, double and triple check your wiring, there may be a problem there. |
#5 |
hi, i also need your help guys, i would like to add an l-pad on my 3 way crossover, is it one l-pad before each speaker or just one l-pad and where it should be placed? many thanx.
#6 |
It sounds wery well when the volume is not so high.The twiter makes the buzz sound when it playes the high notes. I checked 10 times the wiring. The problem is that i don`t know how to calculate tle pad or other thing. It will help me very much if someone modifies my crossover scheme and puts a pad or other thing.
#7 |
To me the inductor on the tweeter looks too small. It may be causing peaking near the crossover point. About twice the value, or 0.22mH would be better. A slightly smaller cap, too, like 1.8uF, if you have it.
For the L-pad, try approximately 1.6 Ohm in series, 30 ohm in parallel. Or buy an L-Pad and wire it in. |
#8 |
Tnx you are the first person that really helped me. thanks you very much.
#10 | |
Usually the tweeter is more sensitive than midrange or bass drivers so it usually needs to be padded down. Here is the L-Pad calculator.
Sand till the end of time |
| problem with crossover | laki101 | Multi-Way | 10 | 21st November 2010 11:37 PM |
| speaker crossover problem | dayking79 | Multi-Way | 4 | 14th June 2009 08:56 AM |
| crossover conductivity problem | REALFLEO | Parts | 16 | 3rd January 2007 05:15 AM |
| Crossover Design Problem | lscangus | Multi-Way | 1 | 25th November 2005 05:07 AM |
| Crossover problem | Soldering Iron | Subwoofers | 2 | 6th January 2005 01:02 PM |
| Page generated in 0.10663 seconds (76.94% PHP - 23.06% MySQL) with 11 queries |
