Old 23rd July 2003, 09:49 AM   #1
Default Any physical tweaks to increase roll-off of woofer?
Just wonder if there are other ways to increase the roll-off of a mid/bass, I don't mean increasing the order of filters but physical tweaks such as damping the cone or just the dust cap. I have a SS 8530 and I would like smooth out the region above 5K .
Thanks.
Old 23rd July 2003, 10:20 AM   #2
octopus is offline octopus  England
octopus's Avatar
Only thing I can think of is dampening a metal basket to take away the ring sound...
Old 23rd July 2003, 11:48 AM   #3
Mass loading with mortite or some other putty at the apex of the cone, or around the dust cap might work, but it will change other parameters in addition to upper end roll off. But it is a relatively reversible tweak, so it might be worth trying. But don't use an oily putty on a paper cone, and don't press it in so hard you can't get it off until you are certain you want to keep it there.
Old 23rd July 2003, 12:24 PM   #4
SY's Avatar
Do you mean HF rolloff? And by "increase in the rolloff," do you mean a decrease in the rolloff frequency?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 23rd July 2003, 12:29 PM   #5
mrfeedback's Avatar
A zobel network can work wonders here.
Eric.
I believe not to believe in any fixed belief system.
Old 23rd July 2003, 12:43 PM   #6
SY's Avatar
Hmmm, I dunno, Eric. If it's a matter of cone breakup, then doing an RC may be a bandage on a corpse. Cone breakup can be sometimes ameliorated with cone dope or varnish, but it's often a function of the boundary conditions at the surround attach. If that's the case, all you're left with is rolling off steeply well below that breakup, because the cone dope will just lower the frequency of the problem rather than curing it..
Old 23rd July 2003, 01:01 PM   #7
mrfeedback's Avatar
Hi Sy,
The dome is very often the source of nasties ime.
Damping the dome by painting with PVA woodglue has worked for me, as has soaking thinned PVA into the cone.
IME a zobel network across the driver directly at the driver connections can quite dramatically reduce HF nasties and enable a rather smoother and more tolerable response from typical woofers.
A zobel network is effectively a snubber network that loads the driver generator output under overshoot conditions and reduces the ringing time of the woofer as I hear it.
Eric.
Did you get those Wolf Blass photos ?.
Old 23rd July 2003, 01:24 PM   #8
SY's Avatar
Yes, I did. I've asked a couple guys to contact you. Thanks!
We now return you to diyAudio.
Old 23rd July 2003, 01:43 PM   #9
mrfeedback's Avatar
Default Lst Friday Night....
The photo is for those who are wondering what Sy and I are talking about.
Sy, tell them to email me is best - I am out and about lately and my mobile has fritzed itself.
Thanks and Regards,
Eric.
Old 24th July 2003, 02:05 AM   #10
Mmm.. Wolf Blass! I believe intake of one bottle should roll off the high pretty well for me. No, I must look for other means.
I tried an overdamped zobel using 8.2uf/10ohm, but still doesn't do well in the 6-8K region, maybe I should increase the cap and lower the resistance, any ideas?
Push Pull woofer physical alignment eRiCdWoNg Subwoofers 1 7th June 2005 09:46 PM
physical CD tweaks? gigatron Everything Else 12 20th October 2003 01:19 AM
Page generated in 0.12312 seconds (75.42% PHP - 24.58% MySQL) with 11 queries
