Possible use of a very low QTS driver?
Old 10th January 2011, 10:59 AM   #1
giralfino is offline giralfino  Italy
giralfino's Avatar
Default Possible use of a very low QTS driver?
Hi all,
I have a TB W4-656 midbass driver. According to the datasheet it should have a Qts of 0,33. I measured instead a value of 0,16.
Apart from the annoying discrepancy, what is the best enclosure for such a low Qts?
TIA, Ralf
Old 10th January 2011, 12:11 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
That seems very low, maybe you need to check your method was correct. If it is that low, you would have to use a ported box.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 10th January 2011, 02:29 PM   #3
phase_accurate is offline phase_accurate
Such a driver would be suitable for a horn, but I do also suspect a measurement error.
Charles
Old 10th January 2011, 02:39 PM   #4
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
First time a Tang Band, (or most any driver) measured lower than spec'd?
planet10 needs your help:
Let's help Ruth and Dave
Old 10th January 2011, 03:43 PM   #5
giralfino's Avatar
I used the added mass method on Limp with this jig: ARTA Jig
Only need to run a sweep, measure driver diameter and DC resistance (on a ohmmeter across terminals). What could I have done wrong?
I suspect that the driver is NOS, and probably sat unused in a warehouse for some years. Could this be the problem?
Ralf
Old 10th January 2011, 03:58 PM   #6
a.wayne is offline a.wayne  United States
Sin Bin
Manufacturers Qts specs are usually lower than actually measurements, never seen it the other way hevar .
Vented box for sure ...
Old 10th January 2011, 05:05 PM   #7
Did it Himself
Ralf
The mass needs to be accurately known and change Fs by approx 50 percent. You need to include a third of the surround in the cone diameter measurement. Did you take a baseline DC resistance reading to account for lead resistance?
So potential for a lot of errors really!
Old 10th January 2011, 05:12 PM   #8
godfrey is offline godfrey  South Africa
How do the rest of your calculated values compare to the specs? e.g. Moving mass, compliance and resonant frequency.
Possible use of a very low QTS driver?Hide this!Advertise here!
what sounds best . . . Low Qts in small cab or higher Qts in bigger cab mikelm Subwoofers 18 15th July 2009 11:46 AM
What Is The Problem With Low Qts Drivers in QWTLs? CarlosT Subwoofers 7 1st April 2008 04:07 PM
Long voicecoil, low Qts drivers TwangBar Multi-Way 0 12th October 2006 01:47 AM
Need 8" sub - low Qts, low Fs??? geolemon Subwoofers 14 19th June 2005 01:38 AM
Low Qts woofer bigwill Subwoofers 19 15th March 2005 08:45 PM
