diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   efficient and simple 2 way (http://www.diyaudio.com/forums/multi-way/180756-efficient-simple-2-a.html)
rg24 9th January 2011 02:36 AM
2 Attachment(s)
So I have the CSS ERT26 tweeter and the Tang Band W6-789E 6.5 woofer, both are efficient. I am looking for thoughts on a simple crossover design? Any help would be great!
Please see attached pics for specs.
rg24 9th January 2011 03:14 AM
would something like 6db on the woofer and 12db on the tweeter @3k work? I am going to use a 1 cu.ft. enclosure with a 8.5" wide baffle tuned to around 45 HZ.
I just dont have much knowledge on x-overs?
tinitus 9th January 2011 03:35 AM
1 Attachment(s)
this xo will work
rg24 9th January 2011 03:48 AM
tinitus:
Thanks for the help!
Do you have thoughts on the values of the components shown in the last post?
tinitus 9th January 2011 12:33 PM
Originally Posted by rg24 (http://www.diyaudio.com/forums/multi-way/180756-efficient-simple-2-a-post2426528.html#post2426528)
hmmm, not so easy without measurements, or listening
for one theres drivers own frequency response
drivers varying impedance result in different component function
tweeter low resonance peak plays a role too
and theres the "BSC"
it means that you have a loss in midbass
its where a voice gets its volume, and thus very important
but usually the midrange series inductor needs to be bigger than the calculated
you could try something like 0.5-0.8mH
paralel cap and resistor could be anything
maybe try 5.2-12uf
resistor, maybe 5.7-10ohm
all those will influence each other
tweeter series cap could be like 4.7-6.8uf
paralel inductor could be a tricky one
maybe from 0.2mH-0.4mH
resistor may not be needed, but try smal valaues from 2.2-5.7ohm
attenuation resistors
you might get away with just a series resistor
but a changed impedance will have influence on xo function
but you need to build a test xo where you can easily change components
do your layout exactly like in the shown schematic
start with cheap components
and please, dont short anything, it could burn your amp
well, you could try and start with just a series inductor on midrange, and a small series cap on tweeter, with a series resistor
maybe you will like it, for a while
chlorofille 9th January 2011 12:42 PM
Tinitus,
That is the exact way I "voice" the crossover for my speakers. (scan-speak based)
Inductor 9th January 2011 12:51 PM
The tweeter looks so bad I would start with a 6dB filter/xover at 4/5K and go from there. 8Ohm, L=0.3mH/C=5uF. I would test a bigger coil, and probably give the woofer better attenuation, one way or the other.
rg24 9th January 2011 01:15 PM
Thanks Tinitus, this will give me a great start!
Inductor: What do you mean this "tweeter looks so bad" do you think I made a bad choice on selection? I chose it because of the price range the
Vifa D19TD-05 3/4" Poly Dome Tweeter and Dayton DC28F-8 1-1/8" Silk Dome Tweeter are both in my price range and easily available, so would one of them be a better choice?
RG
rg24 9th January 2011 01:23 PM
RG
chlorofille 9th January 2011 01:40 PM
I'd go with the Dayton tweeter. It should mate better with the 6.5'' midwoofer and can be crossed over lower (2300Hz or so). 3/4'' domes need to be crossed higher and then you will run into cone break up problems with the midwoofer.
Resources saved on this page: MySQL 18.75%
