efficient and simple 2 way efficient and simple 2 way - Page 2 - diyAudio
Old 9th January 2011, 01:53 PM   #11
Boden is offline Boden  Netherlands
Dear RG,
Although you get some friendly answers on your request, unfortunately none of them hit the nail on the head. Trial and error is not going to produce a good x/o. Speaker x/o is a little more complex than assumed here.
You must measure the chosen drivers in the box you are going to use. Manufacturers sheets are not usuable, in that the speakers usually are not measured in a box, but on an IEC baffle, yielding rather different and much smoother SPL curves. The so called Baffle Step is not present in IEC baffle measurements; neither are all sorts of diffraction effects, that must be taken into consideration, when designing a x/o. Furthermore, TB is notoriously known for its highly optimistic graphs.
My advice: download a free lsp measurement program, such as ARTA or Holmimpulse and import your measured curves (so called .FRD and .ZMA file) into either Boxsim or Speaker Workshop.The learning process will be hard in the beginning, but once you' ve mastered this, you will be able to design almost any system and x/o you like.
Good luck,
Eelco de Bode
Old 9th January 2011, 02:09 PM   #12
rg24 is offline rg24  United States
Maybe I will purchase those as well and use the best of the lot.
I plan to make my first attempt using passive crossover designer and zma and frd files that I have downloaded of both drivers. What is a good crossover point to start with?
Old 9th January 2011, 02:27 PM   #13
Dear RG,
With the Dayton, 2.2 kHz (or even 2kHz) will be fine, provided you apply acoustic 4th order LR. Often a relatively simple electric 2th order x/o will, combined with the drivers own roll off, produce a nice acoustic LR 4 with just a few components. But then again, optimum results can only be obtained by measurement and proper simulations in an x/o program.
Kind Regards,
Eelco
Old 9th January 2011, 09:55 PM   #14
Unfortunately I only have a mac so I think I will just guess on the components-how bad could it be?
Old 9th January 2011, 10:42 PM   #15
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hmm, its said about children they should better crawl for a while, before walking
good for learning, they say
no pun intended
well, no matter what, all the hardware in the world wont make a speaker by itself
need to learn about speakers first
you could start with studying the great speaker man Troels Gravesen http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
efficient and simple 2 wayHide this!Advertise here!
Simple, efficient 5w chip amp trzn Chip Amps 5 12th April 2010 11:58 PM
Efficient Glue... I need help ! ROCKMANDRAKE Planars & Exotics 1 10th January 2010 01:46 AM
Most Efficient Speakers ? EdT Multi-Way 6 18th August 2007 11:55 PM
1 efficient 12" or 2 (far) less efficient 10"s? beady Car Audio 4 8th August 2004 04:55 AM
efficient MTMs castlesteve Multi-Way 10 15th May 2004 01:10 AM
Copyright ©1999-2017 diyAudio
