Old 6th January 2011, 05:57 PM   #1
zobsky is offline zobsky  India
zobsky's Avatar
Default Opinion: has anyone ever used the Audax PR 17 OMO in a midrange horn?
I own a pair of these drivers and was thinking of front-horn (conical) loading them between approx. 300 - 3000 KHz. Does anyone have any opinions on this idea?
Judging by some crude cardboard experiments I tried (crude is a understatement), it was the most natural of the drivers I tried (PR 17OMO, Tangband W8-1772, Fostex FE-166E), though obviously limited in top end extension.
https://www.madisound.com/store/prod...products_id=90
"Any fool can know. The point is to understand" - Albert Einstein
Old 6th January 2011, 06:31 PM   #2
zobsky's Avatar
The abomination . The final build will be a multi sided (6 - 8) conical horn.
Old 6th January 2011, 07:32 PM   #3
Brett's Avatar
It could work OK. Adrian Mack did a conical based around the Eminence A6 some years ago but the Geocities page is long gone. It did 300-2k.
Some discussion about similar stuff in this old thread, which also has a link to Adrian's page - maybe you can find it in the wayback machine.
You could also do an OS without a lot if extra effort and round would be possible using a laminate of sheets, cut with a router and a 45* bit.
Old 9th January 2011, 09:49 PM   #4
zobsky's Avatar
What's wrong with my sim?
From first principles:
Let's assume a Fc = 250 Hz conical
for 4 pi loading, (free space),
speed of sound = 340 m/s
wavelength at cutoff , w = c / Fc = 1.36 m = perimeter of horn mouth
Radius of mouth rm= w / (2 * pi ) = 0.21 m
Therefore, mouth area Am = pi * rm^2 = 0.1386 m2
Assuming Horn length Hl= w/2, Hl = 0.68 m
Substituting these into horn resp, and using a throat aread = Sd, I get awful results, even after tweaking things around. The sim shown has a throat chamber, but there's little difference with / without it.
What gives ?
Driver specs:
Impedance 8 ohm
Resonance 117Hz
Power 100W
Sensitivity 100dB
Re 6.2 ohm
Le 0.73mH
BL 8.24
X-max 0.5mm
Cms 0.2 mm/N
Qms 3.16
Qes 0.61
Qts 0.51
Mms 9.17g
Sd 139 cm2
Vas 5.52 liters
Magnet weight 31 oz
Speaker weight 5.5 lbs
Old 10th January 2011, 12:51 AM   #5
CLS is offline CLS  Taiwan
I've read somewhere that this driver is not very suitable for horn loaded. It seems it likes big mouth. About half an hour of fiddling:
Old 10th January 2011, 01:00 AM   #6
tinitus is online now tinitus  Europe
0.5mm xmax isnt much at 200hz, considering its only a 6"
well, maybe ok at normal SPL
might work better with 500hz xo
Old 10th January 2011, 01:17 AM   #7
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi, Took 30 seconds of fiddling by making the (wave-guide) horn length to ~w/4...I suggest to XO at ~400Hz...
b
Old 10th January 2011, 01:26 AM   #8
zobsky's Avatar
b
Yes, .but in reality, .. you achieved that mainly by whittling down the cone mass to nothing. Not practical
Old 10th January 2011, 01:30 AM   #9
zobsky's Avatar
Yes, I arrived at the same results earlier this week using a large mouth. With that aspect ratio, I'd guess the main benefit would be a a little directivity benefit. It's almost like a shallow waveguide / OB hybrid.
Old 10th January 2011, 01:37 AM   #10
zobsky's Avatar
For what it's worth, one of the reasons I was interested in trying out a conical horn is that the below mentioned router bits should make construction much easier. I picked up some clones of the following bits off ebay last week.
Multi Sided Glue Joint Router Bits
The technique can be applied to tapered boxes ie. conical horns too, as described in
http://mlcswoodworking.com/orderstat...ed-planter.pdf
Audax 170 Midrange - mechanical crossover? critofur Multi-Way 1 7th January 2009 09:04 AM
Audax PR17OMO midrange 4 available badman Swap Meet 8 10th October 2008 03:48 AM
Pr. Usher 9845 2" dome midrange cscmc1 Swap Meet 3 6th February 2007 02:45 AM
Port vs. PR - midrange quality noah katz Multi-Way 2 12th June 2006 04:27 PM
Audax Centre channel crossover for midrange jtfoo Multi-Way 6 30th March 2005 12:21 PM
Page generated in 0.13761 seconds (79.56% PHP - 20.44% MySQL) with 11 queries
