Old 6th January 2011, 09:53 AM   #1
Question Speakers for T-Amp TA2020 under 200$
I'm looking for the best (new and already made) speakers for my T-Amp TA2020 under 200$.
I think buying the Eltax Monitor III. Someone told me that their 89db is perhaps insufficient.
Have you a better suggestion?
Old 6th January 2011, 03:31 PM   #2
DougL is offline DougL  United States
The rule of thumb is a speaker/amp combination should be able to reproduce 102 db @ one meter for "adequate" sound levels.
That would imply that you "need" 16 Watts.
Depending on room size, music and personal preference, you may need more (or less) power.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 6th January 2011, 03:46 PM   #3
chris661's Avatar
102dB@1m?! I suppose it depends on your distance from the speakers, but even so, that's really quite loud.
If you're looking for something smallish and bookshelf sized, I think I'd stand by a 4" full range driver in a ported cabinet. There's also some other small folded Voigt pipe designs that might be worth a look. Then again, it all depends on music choice, how loud you like to listen, and how much bass you want.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 6th January 2011, 04:34 PM   #4
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
This is a DIY forum so if you are looking for a new and already made, look elsewhere.
You may try Dayton PS180 or PS220, they are relatively high sensitivity fullrange drivers. You're not going to find a high sensitivity small two-way bookshelf speaker, they do not exist. Small bookshelf speakers are low sensitivity in order to get some decent bass response. High sensitivity does not come in small packages.
102dB is a fine goal to account for peak levels. 110dB even better if you want to play loudly without strain.
The power of Science compels you!
Old 6th January 2011, 04:44 PM   #5
djn is offline djn  United States
djn's Avatar
Check out the Parts Express Karma Indignia. It started life over on Audio Karma and had Lots and Lots of testing and tweaking before PE showcased them.
Which TA2020 amp? Topping TP20, Amp-03, or Lepai LP-2020 nkx1 Chip Amps 12 4th October 2010 07:14 AM
Zero T-amp TA2020 (eBay) superR Class D 10 23rd September 2010 01:31 PM
Subwoofer out from a TA2020 amp. Mayuri Chip Amps 4 5th August 2010 08:25 PM
Nakamichi SP-200 plate speakers for sale. guitarkirb Swap Meet 0 20th December 2009 03:51 AM
Page generated in 0.06890 seconds (75.55% PHP - 24.45% MySQL) with 10 queries
