Old 5th January 2011, 07:08 PM   #1
paulha is offline paulha  Czech Republic
Default Ciare PT383, Seas U18RNX/P crossover opinions needed
Hi everyone,
I am planning to build a 2-way floor standing speaker using the following drivers
Tweeter: Ciare PT383
Mid/bass: Seas U18RNX/P
Box size 34L, bass reflex, port length 140mm diameter 58mm
I tried simulating a crossover in LspCAD 5.25 and have found a possible solution, see picture. But I am not sure if it is ok.
It was really difficult finding a good linear fit, the only one that looked good was a 2nd order 1300Hz LP and a 3rd order 2600Hz HP network.
I have only adjusted the values of the components a little so that they fit standard components which can be purchased.
Thank you in advance for any opinions/suggestions
Paul H
You will also find the frd and zma SPL and imedance data files for these drivers attached in the zip file.
Old 5th January 2011, 07:32 PM   #2
ermes is offline ermes  Greenland
first of all change the ciare tweeter, to my taste is horrendus
choice seas tweeter for example
bye
Old 6th January 2011, 04:55 AM   #3
Hello Ermes
I already have two of these Ciare tweeters, so that is why I am thinking of using them.
Have you listened to speakers using them?
/Paul H
Old 6th January 2011, 08:07 AM   #4
ok, i understand.
yes i used most of the speakers in the market, including ciare (also the tweeter model you have).
i never like them.
why you don't try to sell them, before starting with a new project ?
then you can buy tweeter (i suggest seas for perfomance/price) that interfaces well with your Seas U18RNX/P
let me know
Old 6th January 2011, 10:25 AM   #5
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Looks like a perfect build tweeter. So ermes may be something else was wrong when it didn't sound right.
Source troelsgravensen site.
thd
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 6th January 2011, 10:30 AM   #6
Helmuth's Avatar
Ciare MT320 is even nicer very nice smooth pole piece drill through.
Ciare looks really like highest level stuff see that step response looks like a ribbon tweeter.
thd
Old 6th January 2011, 01:32 PM   #7
not always excellent projected productcs sounds good !
keep this in mind.
those measurements are more optimistics : does anyone measured the same tweeters ?
to me ciare tweeters sounds very bad.
So you are free to take your decision.
Old 6th January 2011, 02:57 PM   #8
Thanks for your opinion,
I think that I will try the Ciare PT383 after all but I will create an insert in the box for the tweeter so that I can easily change it. The inserts will have different diameters for different tweeters.
With the Ciare PT383 you can use a low cross over frequency, I like that.
I have used SEAS tweeters a couple of times before, they sound ok but are definately not perfekt. My different Dynaudio tweeters always sounded better, but those are not available for DIY anymore.
I may also try these tweeters:
Seas 27TDFNC/GW
and
SICA LP90.28/N92 TW (I have a pair of these also)
/Paul H
Old 6th January 2011, 03:00 PM   #9
Helmuth's Avatar
keep this in mind.
I want to believe you but how can a product that reproduces with out harmonic distortion very good step repose and resonable flatness sound bad.
We have :
Lineair distorsion.
Harmonic distosion.
Step response.
Water fall.
Off axes.
power compression
If these things are good it can only be a good driver.
Or come up with the factor that explains the poor sound. Other wise it become a "yes no" discussion.
Old 6th January 2011, 03:34 PM   #10
i leave in your opinion.
however think about the driver is not only a jam of perfect parameters...
i repeat "those measurements are more optimistics : does anyone measured the same tweeters ?"
about low crossover point : 38mm with 1khz...not so good....how you can go down ???
Opinions re Peerless vs Seas Andy G Multi-Way 5 3rd November 2009 06:01 PM
Has anyone tried the Ciare 8.50 NdMR or the Ciare 6.38 NdMR in a front horn? pk Multi-Way 6 10th January 2009 09:42 AM
Crossover Help And Opinions Needed ka7niq Multi-Way 2 12th November 2006 01:49 PM
Opinions on Zaph's Seas Kit demon2091tb Multi-Way 6 3rd October 2005 04:19 PM
Crossover point for Scan-Speak Drivers - Opinions needed ShinOBIWAN Multi-Way 50 27th March 2005 01:25 PM
Page generated in 0.13561 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
