Old 5th January 2011, 02:24 PM   #1
kelleysislander's Avatar
Default Reverse Engineering a Double Chamber Bass Reflex
All,
I have successfully built a DCR in the past, the one from the Weems book using the 8" woofer, and I just loved it. I knew all my params and was able to utilize the T-S math to calc the ports, volume, etc, and they sounded great, especially on the LOW end!
Fast forward 15 years and I have become the proud owner of 2 large cabinets of approx 9.1 cu ft interior volume. They have two 12" Musical Instrument / PA-style drivers in each, which I will not be using. I have a vintage Pioneer 3-way crossover rated at 270 watts, and I have my choice of 2 different bass drivers:
a. 12" CTS (very little I can find out about these, mags approx 6" x 6" x 1.5")
b. 12" Wharfedale (one has a stiffer surround than the other, butyl rubber it appears, mags same size as the CTS, above)
I know absolutely nothing about the params of the drivers except their dimensions, so my problem is to determine, through experimentation, educated guessing, etc, the correct size and length of the 3 ports needed. I will divide the inner volume into a 6 cu ft and a 3 cu ft space and place the driver into the larger of the two.
Does anyone have any ideas on how to approach this situation? I want to make the ports "stackable" so that I can start with a shorter length and add segments to them (1/2" increments???) until I get the tuning I want.
I am looking for a starting point and any help would be greatly appreciated!
Thanks,
Bill
Double chamber reflex - why is it not used more often? River757 Multi-Way 39 3rd January 2011 02:28 PM
Double chamber reflex rebellion Hezz Multi-Way 13 25th February 2007 05:58 AM
Double Chamber Reflex Vent Question Guss Multi-Way 16 26th June 2004 07:44 PM
quick question about double chamber reflex nobody special Multi-Way 3 11th June 2003 04:54 PM
Page generated in 0.05977 seconds (68.22% PHP - 31.78% MySQL) with 10 queries
