I'm planning to build some small OB bookshelf sized speakers. I have some old woofers from an alpine component set that I just refoamed. My initial rough measurements looked pretty good, so I'm planning on buying a cheap tweeter and sticking it in an open baffle since I don't know the specs. On a side note, would you recommend OB or sealed for woofers with unknown parameters? They're going to be for a computer, so near-field with a wall fairly close behind them.
Here's my question. The woofers originally had grilles on them so they have permanent 'flanges' that stick out about 1/4 to 1/2'' around the circumference of the woofers. I'm guessing that would do horrible things as far as diffraction so I'm planning on rear mounting them. If the woofer is rear mounted and the tweeter is surface mounted or flush with the baffle, how do I compensate for the difference in distance (1/2-3/4'' thick baffle). Should I get a waveguide or something so the tweeter is even with the woofer? One last question, I forget what the rule is for determining phase for passive xovers. I'm planning on 2nd or 3rd order. Any help you can give is greatly appreciated. I'll probably get frequency response graphs of the woofers up later. tl;dr version: rear-mounted woofer, surface mounted tweeter, passive xover, how do I make sure they are in phase? |
#2 |
Here's my rough measurements. It's not entirely accurate since I don't have a sound treated room with an infinite baffle laying around
It was actually measured with my dayton emm6 about an inch away from the dust cap. Don't pay attention to bass and upper treble. It was't that far away from other objects in the room. I was actually holding the driver's magnet with my hand Distortion of each driver dist1.PNGdist2.PNG Frequency response of each driver fr1.PNGfr2.PNG Thankfully they seem to be pretty close. here's one last one using sine sweep instead of pink noise (unsmoothed). FR.PNG I think I've decided on using the aurasound nt1-204-8d for the tweeter. |
#3 |
You'll need an impedance plot to design xovers,
xover order - even orders are phase inverted 'OB' & 'small' are mutually exclusive...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency |
#4 | |
Rules for phase vs. network order are primarily for electrical networks alone: without drivers. Not only will drivers have delay from front mounting/rear mounting but the total depth of the woofer (approx to voice coil) will add delay not compensated for in the simple networks. For that reason it is hard to predict what xover order and polarity will add. Don't add a waveguide for the sake of phase shift. Some network will work with the relative depths that you have. Since you can measure response (can you measure phase?) just start with networks that give response corners at the right place and see how they add. Try the tweeter polarity both ways and if one way is great and the other cancels with a deep notch, you are done. If both ways add poorly then try a different order on one or both drivers and repeat. Herre is a long thread that goes through 1st, 2nd and 3rd order networks for a system and how they impact summing. It tells you all you need to know. Crossover mods for the AR4x - The Classic Speaker Pages Discussion Forums I would start with a damped 2nd order for the woofer (series L and shunt C and R, try 0 to 3 ohms for the R) and 2nd order for the tweeter. Simple networks but they will give a lot of response versatility. Get a variety of crossover parts to experiement with. Don't be afraid to pull turns of an inductor or parallel a bunch of small capacitors to see what different values do. Get a feel for how crossover values effect crossover frequency and especially how L to C ratio impacts corner shape. Understand this and you are well on your way to being a system designer. Regards, David S. |
| Acoustic phase, electric phase,....phase | ermes | Multi-Way | 6 | 27th November 2010 06:17 PM |
| KEF driver phase and the H-B generated phase | dlr | Multi-Way | 11 | 24th April 2007 11:56 AM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| dipole sub H-Frame, phase or opposite phase ? | mbon | Multi-Way | 6 | 19th June 2004 08:36 PM |
