I'm recapping my Pioneer CS-88a speakers and would like to know what the group prefers for fastening the new caps. Is the regular glue gun stuff satisfactory? Or should I go with something else? It's looking like a bit of a
challenge b/c the new caps from Parts Express will be slightly larger than the originals. Thanks in advance Mike in Denver |
#2 | |
I use clear silicone sealant to attach components whenever I build crossovers for my DIY speakers, although many other DIYers use regular glue gun stuff.
Paul Quote:
#3 |
Thanks Paul,
It sure looks tidy in the reference photo you sent. Thanks much, Mike |
#4 |
A zip tie works well too if you have room.
#5 |
I would stay away from any silicone that releases acetic acid when curing (you can smell it). In an enclosed speaker the acetic acid will definitely corrode your components.
I personally use a product called Amazing Goop (available in Home Depot in the US, among other places). It is a solvent-based silicone, so no acetic acid release. It cures completely overnight and sets up within an hour or so. It has a very strong hold but still allows you to remove/swap components even years later, with a little prying/cutting of the silicone. I have attached a couple pics of the external crossover I built for my Infinity RSIIb speakers using Goop and zip ties. |
| What to do after i finish recap? | rg12 | Parts | 13 | 8th September 2010 10:43 PM |
| Exposure 8 recap | EddieB | Solid State | 0 | 2nd February 2010 09:04 PM |
| Recap Problem | 65blkbkgt | Car Audio | 0 | 14th August 2007 09:04 PM |
| First Recap Question | 65blkbkgt | Car Audio | 18 | 1st July 2007 02:38 AM |
| How to recap a mixer? | funkfaker | Parts | 2 | 28th August 2005 05:45 PM |
| Page generated in 0.09668 seconds (58.63% PHP - 41.37% MySQL) with 11 queries |
