Hi all,
I'm fairly new here and to diy audio in general I have been doing a bit of research and found that the sr71 is very close to my price point, and what I wish for in terms of audio quality. It also is available with a pre-assembled crossover which helps me out quite a bit. My problem is however that I live in a tiny apartment 200sqaure feet. I will need to place the loudspeaker about 1 foot next to an unmovable built in cabinet, in addition the back of the speaker will at max be roughly 1.5 feet from the back wall. Would such a placement be acceptable for the rear ported sr71? Or, do I need to move to a front ported or a sealed speaker? here is a rough schematic, please forgive my scaling, I'm limited by the size of the text window. Code:
|-----------------------------------Back wall----------------------------------------------------
Cabinet |
| xxx xxx
| xxx <----- speakers------> xxx
|----------------------| xxx xxx
| <-1ft->
|<----3ft----------->
| <-------wall extending out roughly 8 feet
| Enormous couch |
| Me sitting |
| on me bum |
#2 |
I really cannot see going sealed helping the issues much, toeing in the speakers to cross in front of you might help. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#3 |
RIP
Stuff the ports if the corner becomes a problem.
Best, Bill |
#4 |
The real problem is you'll get an unbalanced image because of the different room load left and right of the speakers; so an amount of damping material stick on the left cabinet could help.
Filling 3/4 of the SR71 enclosure without touching the vent length may work more finely for such a speaker placement.
crazyhub |
#5 |
thanks all. It's good to know that this will be an issue regardless of wether it is a front port, rear port, or sealed speaker. I was considering a much more expensive sealed design as I thought it would eliminate this issue. I'll see how they sound and then stuff accordingly.
#6 |
One of the Contestants of last Summer's speaker contest brought a pair of sealed floorstanding SR71's and they were thought to be pretty good. I believe that he built them for his HT and also used a Sub. Unfortunately, I don't have the frequency response measurements of the FR71's.
FWIW: Sealed mains are generally considered to be easier to integrate with subwoofers. Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
| Zaph|Audio SR71 VS. dynaudio 52SE? | eno | Multi-Way | 11 | 7th January 2011 09:38 AM |
| Zaph SR71 Build | FickleBJT | Multi-Way | 5 | 16th August 2010 11:32 PM |
| Zaph SR71 Build in Concrete | erpiii | Multi-Way | 6 | 18th May 2010 05:53 AM |
| proper vent alternative for zaph sr71 | hotblade6 | Multi-Way | 3 | 3rd October 2008 01:26 PM |
| Page generated in 0.09062 seconds (71.93% PHP - 28.07% MySQL) with 10 queries |
