jbl 2226h built  :^)
jbl 2226h built  :^)
Old 21st July 2003, 11:51 AM   #1
mikee12345 is offline mikee12345  New Zealand
mikee12345's Avatar
Talking jbl 2226h built :^)
http://homepages.paradise.net.nz/quadroph
175Litres 33hz Fb
damping material -needed
rubber gasket-needed
at the moment lots of air puffs out around the woofer :-S
the rubber strip should fix that.
running of 30watts, wil have 60-which if proved stable(eti 480) will be bridged to 150watts.
it models up to 300watts rms within xmax :-D
meanwhile designing basshorn for my mate..
108db/2.83v shiva?
basshorn
Old 21st July 2003, 12:06 PM   #2
phase_accurate is offline phase_accurate
looks nice but:
=> 8 screws instead of four: -needed !!!
Charles
Old 21st July 2003, 12:09 PM   #3
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Originally posted by phase_accurate
looks nice but:
Charles
Hi Charles,
Sorry for the interuption. I've been trying to contact you. Please email me.
Thanks,
Mike,
Great job on your sub.
Rodd Yamashita
Old 21st July 2003, 12:17 PM   #4
mikee12345's Avatar
yeh i know i ran out
im getting some more later..you wouldnt beleive how hard it is to find some decent screws for mounting a speaker!
nice webcam quality pics lol,camera scans later :-D
did you know i could actualy fit a surprising amount of my body inside the speaker cut out while glueing the top of the port some more :-P
<skinyboy>
argh time for sleep! Tech in 7.5hrs!
Old 21st July 2003, 01:58 PM   #5
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
jbl 2226h built  :^)
BTW Behringer bass processor that you wanna buy is a very nice thing
Does wonders in da club especially on some techno tracks.
What is that thing on your home page???
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Old 21st July 2003, 02:18 PM   #6
Centauri is offline Centauri  Australia
Nice box - keep up the good work.
eti480 amp - reasonable for a simple amp, but would not trust them bridged. With a few modifications and a bit extra voltage supplied, these amps will run quite well at around 150W - let me know if you want more details.
Cheers
Old 21st July 2003, 06:37 PM   #7
Nappylady is offline Nappylady  United States
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
If I could suggest, flush-mounting the driver makes a huge difference, also if you put the driver *inside* the box to screw it in, rather than outside, it will help the box farting alot.
Looks good! I wanna build some like that.
Old 22nd July 2003, 12:21 AM   #8
mikee12345's Avatar
which thing :P
the super huge woofer?
yes please email me-i may go for a jayacar 350 watt amp instead or 250watt. i have 300va transformer 28-0-28
osmium@paradise.net.nz
flush mounting good idea although the wood is only 18mm mdf,andi dont have router they cost HEAPS to rent for a day!!!!
i cant mount it from inside the box unless now i put a baffle on the front
Old 22nd July 2003, 10:54 AM   #9
Email sent re: eti 480 mods
Regards router - all you really need is a small trimmer router. They are fairly cheap and Makita & Royobi make quite good ones. They are also easier to hold & use than full size router - you will be amazed how often you will use it !
Cheers
Old 23rd July 2003, 09:49 AM   #10
mikee12345's Avatar
8 screws mount the jbl now
put some of this sealant strip for doors <rubber> against frame and cut out.seems much more better.i still dont trust,excursion is higher than i thought it would be.
impedence curve measurement>speakerworkshop wudnt do it>
silicon sealant soon,seal everything,and paint,then
Power and RS SPL meter...
the spl in port is high and nice! :P
jbl 2226h built  :^)Hide this!Advertise here!
Has any one built this 1KW amp? VT Calais Solid State 253 19th July 2017 07:51 AM
What makes the JBL 2226H such a popular driver? Defo Multi-Way 39 12th April 2017 05:36 PM
WTB: JBL 2226G (pair) or blown 2226H/J and 1&quot; compression drivers mikey7182 Swap Meet 1 6th March 2009 03:43 AM
JBL 2226H & 2426H cd/2370 horn combo in OB project..? JandG Multi-Way 6 1st December 2008 06:40 PM
FS: JBL 2226H - $150 + shipping taloyd Swap Meet 7 30th January 2008 09:31 PM
