Hello,
I'm building a 2-way using the Vifa XT25tg30-04. When I model the crossover I get some funny results for the HP filter. In both Speaker Workshop and Passive Crossover Designer (I am aiming at an acoustic L/R2 at around 2500hz) I end up with a series capacitor value exceeding 30uf! Does this seem reasonable? Has anyone else modeled this tweeter and found similar results? Are my FRD and ZMA files way off? The other odd thing is that I have these in a box with an old Dahlquist crossover I had laying around, which appears to be a pretty normal 12db/octave crossover, and they sound great. Just thought I'd check with someone before I shell out the money for those huge film caps. Thanks, John |
#2 |
You can always try inexpensive electrolytics back to back with small value film in parallel to get 30 uF and try it out. If it is OK you can buy the expensive film type. ( say 2x47F + 2x10uF elcos will give 28.5uF . That's within 5 % of your value). However you might have to measure the cap value as elcos have a very wide tolerance range.
This doesn't answer your question if the value is correct but thought I'd suggest that you confirm it works well ( if calculated correctly!) before plonking good money for expensive film caps.
AM |
#3 |
Hello,
I am using those tweeters and like them. I have not yet built a XO i am using a digital XO. Before you go expensive try this capacitor. Dayton DMPC-30 30uF 250V Polypropylene Capacitor | Parts-Express.com I have used other values and liked the results. DT All just for fun! |
#4 |
Don't forget to add a notch filter at the tweeter's resonance (450Hz).
[100uF + 1mH + 4.7R] across the tweeter.
Sand till the end of time |
#5 |
It is about double the value I would expect, have you double checked the impedance and DCR values entered into the program??
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#6 |
Thanks, everybody, for your replies.
My first thought was to use cheap electrolytics for testing purposes but I am concerned that the actual filter slope will extend too deep into the bass and damage the tweeters-- I read somewhere they have xmax issues and can be easily damaged. I have checked and rechecked the DCR values, and the ZMA files and they both look accurate. If I model a tweeter with similar characteristics like the RS28a I get a similar result. This really does seem about double to triple the Series capacitor value I would expect. One more thing... when I try to model a known filter like Zaph's ZD5 or one of Troels Gravesen's designs the SPL graph look really strange. I must be doing something wrong, right? No else experience this? John- |
#7 |
I did a 2 way (Peerless HDS PPB 830860).
Crossover freq. is about the same but the capacitor is only 6.8uF. Could you post your schematic ? |
#8 |
Hi, very highly likely, cross checking needs to give consistent results, rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#9 |
#10 |
what is the value of Rlpad1? is that 170 ohms (way too high)?
the impedance of the tweeter is ~ 4 ohms at 2500Hz, so for LR the cap should be ~ 8uF, the inductor ~ .5mH
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
| Vifa xt25 tweeter | Per Nielsen | Multi-Way | 67 | 12th March 2010 05:58 PM |
| Vifa XT25 | Jonasz | Multi-Way | 30 | 19th January 2007 05:18 AM |
| Series x-over for peerless 830875 and vifa xt25........ | Gavinator68 | Multi-Way | 4 | 12th July 2006 10:55 PM |
| Vifa XT25 is rolling off too soon? | K-amps | Multi-Way | 17 | 4th January 2006 11:38 AM |
| Vifa xt25 question | Clueless | Multi-Way | 8 | 10th September 2003 09:00 AM |
| Page generated in 0.12162 seconds (73.67% PHP - 26.33% MySQL) with 10 queries |
