Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Trying to come-up with a great two-way & found out that Parts-Express.com makes a replacement 15" driver for the Realistic Mach One. I sold the Mach one when I worked for RS a long time ago...Now we combine the two particular loudspeakers from the past & create something very different.
Running the numbers for the 15" 'Mach One'.....I just knew it was going to be ideal for sealed systems.& I got 34.92 for EBP.........right in the range for sealed. That was to be expected as the original was a mere Twenty five or so inches high, maybe seventeen inches wide & only...say Fourteen inches deep. So when I crunched the numbers for the "perfect" .707 I came up with 20.35 cubic feet......How did they squeeze it down so far? Pushing towards 1.0 Qtc way under-damped. So I would have a enclosure 26" wide,32" deep,41" High. Trying for the narrow Mega-tower look. With the Heil mounted on top,I could set it 'back' on the enclosure trying to correct any phase shifting. The cross-over will be tricky as the overlap is very narrow. Any ideas??????????? __________________________________________________ Rick......... Last edited by Richard Ellis; 28th December 2010 at 03:11 AM. Reason: typo |
#2 |
49 - for the 16th time
Hello Richard - P10 and Chris B did something along these lines a few years back - but they used a now defunct 9 inch Fostex for the woofer. Scroll down a bit and you will see a tall speaker similar to what you are talking about - and next to it a box that uses a larger driver but without a AMT.
planet_10 hifi Despite what they say I would be careful about crossing the AMT lower than 2 kHz - I cross mine at 6 kHz 1st order with a 6.8 cap and use them as tweeters. The AMT1's I have were made in the 70's tho - so the new ones might work better. BTW - what is the part number you are using for the replacement woofer?
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod Last edited by c2cthomas; 28th December 2010 at 05:21 AM. |
#3 |
I used the Big Heil on my three way system. I have an active crossover and could roll out the mids and bring the Heils down to meet the woofs. They say they can go down to 800hz, but anything under 2K is REALLY thin. Even from 2K on up, IMHO, is REALLY thin compared to my 350hz round Edgarhorns. I think the Heil is the best "tweeter" available.....but that is just me. If you can, try to listen to them before commiting. They seem to have a "love em/hate em" effect on people.
#4 |
What's the natural roll off on the Heils, 2nd order or closer to 3rd order?
And what's the actual sensitivity? I've seen all kinds of stuff from 92dB to 100dB quoted. |
#5 |
Richard,
I have a great hint for you, download this document and start reading....http://www.intertechnik.de/module/1385061.pdf A speaker for a weak amp, but a large room. Quite efficient, the stereoplay Hurricane! Cheers, Martin |
| My own take on Air Motion Transformer | NV&H | Planars & Exotics | 4 | 11th March 2010 04:08 AM |
| Heil Air Motion Tranformers from ESS AMT4 | Scott Novak | Swap Meet | 2 | 22nd March 2009 01:22 AM |
| FS: Large Heil AMT Air Motion Mid-Tweeters | Magnetar | Swap Meet | 4 | 2nd January 2007 01:32 PM |
| DIY Air Motion Transformer | OliverD | Multi-Way | 55 | 10th April 2005 12:28 AM |
| Has anyone used 'Heil Air Motion' Transducer? | goldyrathore | Multi-Way | 13 | 4th May 2004 04:48 PM |
| Page generated in 0.08841 seconds (74.48% PHP - 25.52% MySQL) with 11 queries |
