Hey there,
I plan to build a pair of active monitor speakers from a broken Yamaha keyboard (all speakers magnetic) : Woofers: 283 Yamaha / XJ999 / 8Ohm 20W Tweeters: 281 Yamaha / XK000 / 8Ohm 20W On the original board, the speakers are wired in a "not so crossover fashion" with the woofers connected directly to the amp and the tweeters fed through a 3.3uF bipolar electrolytic capacitor. If I got the math right, that gives us a 1st order Butterworth high-pass around 6000Hz. Considering a 2nd order Linkwitz-Riley crossover, is it ok to aim for a 3000Hz cutoff frequency (from a 6000Hz at 6dB rolloff (1st order) to a 12 dB rolloff (2nd order)) ? That would mean C=3.3uF and L=0.85mH. Thanks for your time. |
#2 |
Impedance varies with frequency, '8' ohms is just nominal, so you need to measure the actual impedance of your drivers to get accurate results. Download ARTA, make a simple jig & you're on your way...
ARTA Download, AudioBlog: A simple loudspeaker measurement jig for ARTA
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
| Frequency Cutoff | habsrock93 | Full Range | 2 | 21st August 2007 01:32 PM |
| Crossover cutoff frequency ? | Fradbut | Multi-Way | 3 | 22nd January 2007 09:31 AM |
| Low frequency cutoff calculation for Noninverted. | 5150ed | Chip Amps | 19 | 11th August 2006 02:58 PM |
| W Bin -vs- L 36 Low Frequency Cutoff | OMNIFEX | Multi-Way | 11 | 14th March 2003 07:15 AM |
| Reasonable low frequency cutoff | markkanof | Multi-Way | 5 | 12th June 2002 10:14 PM |
| Page generated in 0.07147 seconds (74.44% PHP - 25.56% MySQL) with 11 queries |
