S15: Econowave DSP - a Constant Directivity vs Dipole study
Old 15th December 2011, 08:28 PM   #151
badman is offline badman  United States
badman's Avatar
Originally Posted by pos View Post
Nice!
Would you have a side view of your foam plug?
And, what sort of foam did you use? Hard to photo foam.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 15th December 2011, 08:51 PM   #152
AllenB is offline AllenB  Australia
I'm looking at throat wall damping at the moment, how do you guys do it with plastic horns? I've thought of casting poly around it but I'm concerned it will not bond and will separate. Maybe I could just damp with some kind of bituminous putty?
...and on the foam, I have used dacron (with netting to hold it in place) with no negative effects in the end although it takes time to match the stereo pair...just FWIW.
Old 15th December 2011, 09:24 PM   #153
gainphile is offline gainphile  Australia
gainphile's Avatar
Originally Posted by Jeroenkv View Post
Hi Gainphile,
Respect for your work! One question, did you try Econowave and a 15" woofer in OB?
Can boxed low - mid be the reason for wins to dipole?
I'm using Econowave DE250 with AE speaker LO15 in OB.
BR,
Jeroen
Yes, somewhere in this thread I have posted a conclusion on my dipoles vs. this narrow directivity speaker. I had not changed. If I had to "summarise the summary" it would be like this:
- Econowave/narrow directivity: Better tonality and driver integration, but lacks that last bits of spatial illusion.
- Dipole: Better spatial/auditory scene reproduction, but correct tonality is a real challenge (perhaps too much room influence).
These days what I'm trying to do is to document them. I've started the one for the ewave.
http://gainphile.blogspot.com
Old 15th December 2011, 09:27 PM   #154
gainphile's Avatar
They are 30 ppi "reticulated foam", more popularly known as "mericell" in Australia.
Paul had done a great find:
Red Spade Audio: Where can I find reticulated foam in Australia?
Old 15th December 2011, 10:34 PM   #155
badman's Avatar
Ah, very cool. The stuff I use I got cheapie at a fish store, couldn't say porousity with any certainty, but it's very open and very large cells. I found the effect pretty immediate and obvious, and my version had less foam than your, full-up, version. Benefits of noise sensitivity perhaps, I rarely go to anywhere with amplified music.
Old 16th December 2011, 06:49 AM   #156
Jeroenkv is offline Jeroenkv  Netherlands
I can relate to your conclusion, but to my experience auditory scene has allot to do with boxed mid. Using an Open Baffle woofer helps allot. The other aspect is diffuse highs, but you good also argue that a Dipole ads air/room that is not there?
I compaire Econowave with Open Baffle 15" with my other system a 3-way dipole with Seas mid (M15CH002) and BG Neo3W. Both active with MiniDSP.
Old 6th April 2012, 05:04 PM   #157
TheaterChad is offline TheaterChad
Hello, My first post here,
I'm looking to build this design of speaker, wondering if there is a regular crossover that can be installed in the speaker rather going with active DSP style, I'm new to the diy world, but since I have one set of klipsch KG 5.5 speakers in my family room, I need another set of speakers to fill the room, and since I have horn tweeters, I thought these would fill in perfectly, any suggestions or help would be greatly appreciated, thanks.
Old 5th May 2012, 03:37 PM   #158
gainphile's Avatar
Hi I missed your PM! Sorry.
In any case they are not my design but by late Zilch's. I only did the active/dsp version.
Old 5th May 2012, 03:40 PM   #159
ra7 is offline ra7  United States
Originally Posted by TheaterChad View Post
Well, after I sent a pm to gainphile about me wanting to build several of his econowave speakers, and after 2 plus weeks and no reply to a PM would have me decide to take my money elsewhere.....
And that would be your loss and your loss only. Tons of info here, parts-express forums and audiokarma.
Old 13th June 2012, 02:05 PM   #160
Gainphile,
I have to apologise for my previous post, as I was under a serious medical issue, my gallbladder ended up getting infected and I was turning yellow, and I needed emergency surgery, I've been on the mend for several weeks, I was really sick, and I was a bit more frustrated than normal.
With so much information that I've read and like over 950 pages from Zilch's thread, I was trying to just get some info from you, or buy some components from you, when you read all the pages that exist, it's so difficult to see what people are using, and if someone like me can't build crossovers, I thought maybe you could sell a set of conventional cross-overs for a price, that's all I was trying to ask or get some helpful info. Thanks!
S15: Econowave DSP - a Constant Directivity vs Dipole studyHide this!Advertise here!
Constant Directivity Horn EQ Horizons Multi-Way 4 19th December 2008 11:41 AM
Constant directivity EQ Saurav Multi-Way 11 19th May 2008 02:41 AM
Constant directivity horn - or waveguide? hasselbaink Multi-Way 6 1st April 2008 01:24 PM
