S15: Econowave DSP - a Constant Directivity vs Dipole study
Old 21st March 2011, 10:53 AM   #141
The Space Egg Corp is offline The Space Egg Corp  England
The Space Egg Corp's Avatar
Originally Posted by gainphile View Post
High:
High pass filter: 1khz LR4
Horn Notch: 1900hz, -4db, Q=1.4
Gain: -11db
Delay: 0.1ms
Tweeter protect: 68uF non-polar capacitor
Low:
Low pass filter: 1khz LR4
Driver notch 1 : 704hz, -3db, Q=3
Driver notch 2 : 1037hz, -3db, Q=6
Hi gainphile
Just saw your speakers on the site.
I am looking to enjoy highish frequencys from a large dia. LF driver, and cross over a compression driver at a 'low' frequency also.
My bets are that this is totaly possible, although there seems to be a lot of 'conventional' opinion out there that this is not possible.
I was very pleased to see that you have ignored the 'conventional' and done just that.
I'm sure that it is 'conventional' dogma that puts people off trying this more often than seems the case.
Good to hear they sound to your ears a winner.
Cheers
Simon
P.S. I am wanting to use the square 90x90 version of the waveguide you have used, which also some have speculated won't work that low.
Tear up the rule book and just listen.
Nice work gainphile.
Old 21st March 2011, 03:24 PM   #142
Sheldon is offline Sheldon  United States
Now put some reticulated foam in those waveguides, ala Geddes, and tell us what you think.
Sheldon
Old 21st March 2011, 03:50 PM   #143
badman is offline badman  United States
badman's Avatar
Sheldon
And some foam projecting forward from the front baffle, around the mouth- softens that edge termination, makes it act partially like a much bigger horn.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 22nd March 2011, 06:08 AM   #144
gainphile is offline gainphile  Australia
gainphile's Avatar
The Econowaves are not gedlee clones ... but yes I'll try the foam one day. I've had good reports with non-gedlee speakers too and they're not too expensive.
http://gainphile.blogspot.com
Old 22nd March 2011, 06:21 AM   #145
Sheldon
Just use some decent grill cloth.
If you must have 'foam'...
Try a slice of saucepan scourer.
Thats quite good for getting an acceptable sound from any over-active metal tweeters.
Cheers
Simon
Old 22nd March 2011, 03:13 PM   #146
Nor are my Unity's.
The issue here, is not excessive highs, but internal reflections in the horn - the things that make it sound like a horn. The foam attenuates those reflections, and requires some depth. I fill all the way to the phasing plug of the compression driver. If the horn is fairly shallow, you can fill the the front. If it's deeper, a partial fill is nearly as effective. In my hands, a depth of 10cm or so does most of the work.
Sheldon
Old 24th March 2011, 11:04 PM   #147
gainphile's Avatar
Instinctively I don't like anything blocking the HF range.
But I'm open to ideas. I've placed orders for the foam.
I will post measurements and listening impression once they arrive.
Old 28th March 2011, 03:04 PM   #148
gainphile's Avatar
Default ewave + foam
This is my eWave *with* foam
The foam causes attenuation of -2db.
blue: original
black: with foam insert
The attenuation is quite uniform, as shown by compensated graph below. It tracks very identical to no-foam. So this is good. Only in extreme highs that it deviates.
blue: original
black: with foam insert and +2 db.
The changes to the sound is subjectively subtle, and that is consistent with the above plots. I thought horn coloration is reduced, but at the expense of airy-ness. It's a good tradeoff.
Old 28th March 2011, 03:45 PM   #149
pos is offline pos  Europe
pos's Avatar
Nice!
Would you have a side view of your foam plug?
Old 15th December 2011, 07:49 PM   #150
Jeroenkv is offline Jeroenkv  Netherlands
Hi Gainphile,
Respect for your work! One question, did you try Econowave and a 15" woofer in OB?
Can boxed low - mid be the reason for wins to dipole?
I'm using Econowave DE250 with AE speaker LO15 in OB.
BR,
Jeroen
S15: Econowave DSP - a Constant Directivity vs Dipole studyHide this!Advertise here!
Constant Directivity Horn EQ Horizons Multi-Way 4 19th December 2008 11:41 AM
Constant directivity EQ Saurav Multi-Way 11 19th May 2008 02:41 AM
Constant directivity horn - or waveguide? hasselbaink Multi-Way 6 1st April 2008 01:24 PM
