Old 20th July 2003, 01:44 PM   #1
ergo is offline ergo  Estonia
Default Fat Margaret Loudspeaker Project
I finished preliminary web page on my Fat Margaret Loudspeaker Project...
http://www.hifiklubi.ee/fat_margaret_project/
The design is closed box standmounter using Seas W17E-002 woofer and Seas Millennium tweeter.
Ergo
Old 20th July 2003, 02:22 PM   #2
ksl is offline ksl  Estonia
ksl's Avatar
Send a message via MSN to ksl
blue color
Old 20th July 2003, 03:01 PM   #3
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
Send a message via Skype™ to VEC7OR
Nice
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Old 20th July 2003, 09:16 PM   #4
I love the look of the cabinets
what materials or finish did you use?
My current project is only lacking a decent finish.
MDF cabinets , i do not want to veneer.
regards David
regards David
Old 20th July 2003, 10:11 PM   #5
indrek is offline indrek  Estonia
I like them! This are with very interesting design and Seas speaks on itself!
Nice work!
Old 20th July 2003, 11:17 PM   #6
316a is offline 316a  England
316a's Avatar
Default Spray on goop
regards David
Looks like Texcoat / Stonecoat available from Homebase . Can be expensive , even spraying a small pair of cabinets with the stuff but gives a nive finish
316a
Old 21st July 2003, 05:30 AM   #7
I used a granite texture spray paint.
http://www.duplicolor.ee/tooted/granit.htm
And no it is not that expensive, at least here in
Estonia. One bottle is approx 10$ and I used 1 bottle per box.....
Old 21st July 2003, 05:46 AM   #8
This is how the crossover looks at the moment.
I wanted to make it as easily accessible as possible as I might wanna tweak it.
Ergo
Old 21st July 2003, 09:28 AM   #9
Shaun is offline Shaun  South Africa
Shaun's Avatar
Default Choosing baffle width
Hi, Ergo
I read how you did your measurements. I have a question: with your rounded box, how did you decide what baffle width to specify in your baffle step simulation?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 21st July 2003, 01:25 PM   #10
Lower part of the frontside around the woofer is 18cm wide. So this is the value I used for calculating baffle step.
Ergo
line array loudspeaker project daly2k Multi-Way 59 2nd February 2011 05:31 PM
Question - B&W drivers and center loudspeaker project Mrpong Multi-Way 0 15th May 2007 02:53 PM
postmortem of loudspeaker project mazurek Multi-Way 23 21st March 2006 04:24 PM
3 way loudspeaker Project! Guijs Multi-Way 3 19th October 2005 06:01 AM
Behemoth Loudspeaker Project Ignite Multi-Way 8 19th January 2003 07:02 PM
Page generated in 0.10329 seconds (73.26% PHP - 26.74% MySQL) with 11 queries
