Old 24th December 2010, 07:28 PM   #1
Scott L is offline Scott L  United States
Default Mid-Bass: Absorbtion needed ?
Looking to get feed back and opinions on this:
With respect to the mid bass enclosures of my multi-way system, operating in the range of 60-250 Hz, and with the largest internal dimension of said enclosure being 23 inches, do i need to use any absorbent materaial, i.e. fiberglass, etc, at all ?
p.s. the crossover slope is 48 db/ oct. (active, of course)
Old 24th December 2010, 08:51 PM   #2
If you are concerned about box modes ,with that 23" dimension there should be a 1/4 wave mode @ 150 hz. I sometimes use internal baffles @ 20- 35 degrees to any box wall to break up modes. If this is not what you are talking about, ignore this then.
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 25th December 2010, 10:38 AM   #3
Default Bingo: Spot on !
Thats is exactly what I was concerned with, and I am going to use similar to what you suggested. Thanks so much for the heads up !!
Old 25th December 2010, 03:36 PM   #4
Of course you want something to absorb soundwaves bouncing around in the box. Any design i've ever made has sounded clearer with some good absoptive materials in there. Don't use plain old polyfill or acoutic foam either. Some good, cheap rigid fiberglas attached to the walls or even better Bonded Logic stuffed in there. Just google around for some.
Greg.
Which Scanspeak mid/bass for 2-way? andyjevans Multi-Way 34 28th July 2010 05:04 PM
Acoustic Absorbtion for Sub spadez Subwoofers 7 7th December 2009 04:06 AM
Which bass/mid for this application? internationalmanofmystery Multi-Way 3 5th September 2009 11:33 AM
Low frequency absorbtion techniques Bazukaz Everything Else 12 24th August 2006 02:01 PM
What mid/bass to choose?? Bylie Multi-Way 2 29th November 2002 11:39 PM
Page generated in 0.08973 seconds (74.08% PHP - 25.92% MySQL) with 11 queries
