Old 29th December 2010, 09:38 PM   #41
TMHutson's Avatar
I am curious to see if you like the sound of your sealed enclosure once it is done.
Andale pues!
Old 29th December 2010, 10:18 PM   #42
Believe me, I'm more curious than you Meanwhile I am using cheap aiwa speakers. I want to finish right now these new enclosures.
I am quite sure that work perfectly with subwoofers.
Anyway, I'll measure them when finished. I have to figure out how to make a good measurement below 300hz. I donīt know if I can do that without an anechoic chamber. In that case, you're going to have to believe only in my ears: (
Old 30th December 2010, 02:02 AM   #43
Below 300Hz you have to use nearfield measurements and trust the physics.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 30th December 2010, 02:07 AM   #44
Understood. It is worth making the measurements outdoors? I have a garden in the back of my house, about 30 x 9 meters, no walls in between which could disturb. I never thought of making the measurements there in a day without wind or noise, and pointing the enclosures to the sky, to minimize unwanted reflections due to the floor.
What do you think about this?
Old 30th December 2010, 02:18 AM   #45
Hi, Take a look at Paul Messengers articles on measurement at Stereophile, rgds, sreten.
Nearfield measurements for the bass end can be done indoors with the right gating.
Old 30th December 2010, 02:24 AM   #46
Thanks sreten, iīll take a look at those articles
Old 31st December 2010, 12:50 AM   #47
Well, I bought the glass wool. I couldnīt find rock wool. The construction of the boxes will take me some days longer than planned, because I've added some wood details. But I tried for a few minutes a single box, not stuffed inside, and looks promising. Of course, bass is not devastating, but I had the impression that can be used completely without subwoofers. I also try to equalize, increase 4db 50hz, 4db 60Hz 2db at 70hz, and they're pretty much like the bass reflex enclosure. I didnīt notice any excursion problem. Surely with the filling will be much better.
What do you recommend me for filling? Can I use only glass wool on all sides of the box? Or itīs better combinate with polyfill?
Old 31st December 2010, 02:10 AM   #48
Hello,
The last set of speakers i stuffed with raw wool from a sheep. The real thing worked well. The idea came from an old Linkwitz paper.
I bought the wool on line from a woman that sells wool from her few sheep to DIY folks that spin their own yarn, pretty cool I thought.
DT
All just for fun!
Old 31st December 2010, 02:15 AM   #49
But itīs late DT, iīve bought glasswool yesterday.
Someone recommended me to use glass wool in the bottom of the box and polyfill in the rest of the walls. But because I bought a lot of glass wool, I wondered if it would be correct to place on all sides and not use polyfill.
Old 31st December 2010, 02:49 AM   #50
Hello,
I learn by doing as well.
The way I think of the stuffing is like adding density to the air in the box. Back when i read that the fiber glas should be attached to 3 inside surfaces top, side and back to reduce reflections. Perhaps all 6 inside surfaces. Other boxes are completely filled with soft fluffy stuff. This is increased density fill concept. Some speaker software programs have a blank to fill in for weight of the stuffing added. The idea is that as the box filling air and stuffing has density (weight) that will adsorb heat from the adiabatic compression of the air. On the negative pressure side of the sound wave the stuffing gives the heat back, the oppisit of the heat of compression. The stored energy or heat is the equivalent of added box volume. The stuffing also helps keep the sound inside the box from bouncing around like a ping pong ball.
The short version staple the fiberglass batts to the inside walls and weigh out 6, 8, or 12 Ozs of pillow stuffing into each and see how you like how it sounds.
To answer your question directly, it is all good!
No sheep?
DT
All just for fun!
Another Peerless 830875 Execution swin1 Multi-Way 16 4th October 2010 04:19 AM
Peerless 830875 vs SEAS CA18RNX cs Multi-Way 0 5th March 2008 11:51 AM
Peerless 830875 Nomex????? Gavinator68 Multi-Way 2 8th November 2005 01:55 AM
Peerless CSX 10 inch in sealed box or TL? ashok Multi-Way 12 23rd January 2004 10:24 PM
good sealed box size for a 10" Peerless XLS sub peerless Multi-Way 1 1st August 2003 09:01 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright Đ1999-2013 diyAudio
