Old 26th December 2010, 09:06 PM   #11
@sreten: The enclosures I have now are bass reflex. I want to try a sealed enclosure for the reasons mentioned earlier, which left me very curious.
@DualTriode: I think the same way as you. I prefer the sound of sealed enclosures. And for that, I have two 15-inch subwoofers. But on the other hand, I like to use the Peerless, Without the Urgent Need for subs. As well I said before, I do not look good bass in them. Just looking for a bass that accompanies it. The only thing that interests me is that I can hear the range of 55-65Hz in a fairly decent way. It is not my intention to get more down in frequency with these monitors.
Old 26th December 2010, 09:08 PM   #12
F3 is not the issue, F6 and F10 matter far more in reality, and
optimising for these gives you a far better transient response.
This driver in small sealed will not have good bass, vented
done properly IMO will get down to 40Hz or so with a large
maximum SPL / lower distortion advantage, I cannot see
in this case sealed being preferable in any sensible sense.
rgds, sreten.
I've got nothing against sealed, but not these drivers without a sub.
Detuning your ports with a foam lining is by far IMO your best bet.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 26th December 2010, 09:59 PM   #13
Hello,
I will jump in with more opinion.
It depends on time place and purpose. Mood music for the women in your life does not need chest pounding bass decibels.
Here is a thought: build the bass reflex boxes and provide the ability to blank off the ports for the times you may want to roll into the 15 inch bins.
Something you likely already have in mind is the “cabin effect”. Moderate to smallish rooms have the bass increase in real db’s due to the relationship between the wavelength and room size.
The Peerless may perform better than they appear on paper in the real space.
DT
All just for fun!
Old 27th December 2010, 03:31 AM   #14
I like the idea of making a new bass reflex, with the possibility of plugging the ports. Could make about 13 liters, maybe a little less, to work well in both bass reflex and sealed when I plug in ports. To compensate for the decrease in size in bass reflex mode, I can try tuning the port at 50-53Hz. 40hz tune to me seems crazy, the group delay is very high.
Old 27th December 2010, 04:11 AM   #15
Hello,
The Madisound bass-reflex recommendation tuned to 53 Hz is 12 L.
I was thinking more of a cap (rather than a plug) with 2 to 4, ¼-20 cap screws with a T-nut like this pressed in the inside of the box.
T Nuts, Insert Nuts, Propell Nuts, Weld Nuts
DT
All just for fun!
Old 27th December 2010, 04:17 AM   #16
It´s a good idea too. Tomorrow i´ll start with the enclosures. Thanks for the tips
Old 27th December 2010, 06:41 AM   #17
jerome69's Avatar
An alternative could be an aperiodic box
Old 27th December 2010, 04:45 PM   #18
mondogenerator's Avatar
With good bass I make reference to something that it accompanies. I do not looking for incredible low. Just something that allows me to enjoy, for example, a good jazz in a fairly decent way without an urgent need for a subwoofer. To me is enough that I can hear the range of 55-65Hz, but as I said before, without arriving at anything extreme. For something extreme, I have two 15 inch subwoofers in a sealed box.
In a sealed box of 8 liters, the F3 is 80hz, not 85hz. This is a detail, but everything counts
personally, i wouldnt be scared to use them in a sealed box. after many years of messing with both sealed and vented systems, i have come full circle and once again i prefer the small sacrifice in 'maximally flat' bass extension of a vented design to obtain the smoother, and transiently better response that a closed box will produce. room gain and the fact i listen within about 10ft mostly, means that often the result is better than the vented boxes i have. id even go as far to say that a low Qb (sub 0.707) sealed box can be even better, and ultimately flatter, when room gain is factored in. group delay on bass is noticable in many vented systems, and until recently i was sceptical about its audibilty. all these things combined with the fact you will sometimes be using a sub, makes me think that closed is definitly the way to go. ive often found jazzy drums and double bass sound far better, although less 'full' when i used the same driver in 'optimal' boxes both vented and sealed for comparison. and this is using the visaton AL130 which also has a very high EBP(pointing to a vented design) but the qts of 0.4ish means its a little more versatile. group delay in WinISD is cut from about 15ms to less than 6. ive also tried this with a old pair of audax ap130zo, with slightly less impressive results. the Fs of the audax is about 58hz thought, and the EBP way over 100 if i recall correctly.
i hope that maybe this is of some help
It still amazes me every time I get something right
Old 27th December 2010, 05:04 PM   #19
40Hz tune to me seems crazy, the group delay is very high.
Tuning it wrong for the wrong reasons IMO is not a good idea at all.
The tuning is perfectly sensible to me. The group delay is inevitable
and FWIW superior to the higher tuning interpreted correctly, as
are the other parameters except for maximum F3 bass extension.
rgds, sreten.
This driver IMO does not suit sealed well for full range, no subs.
Suggested alignment is quasi-first order rolloff for room matching.
Old 27th December 2010, 06:10 PM   #20
Agreed with Mondo.
Sealed much better.
Another Peerless 830875 Execution swin1 Multi-Way 16 4th October 2010 04:19 AM
Peerless 830875 vs SEAS CA18RNX cs Multi-Way 0 5th March 2008 11:51 AM
Peerless 830875 Nomex????? Gavinator68 Multi-Way 2 8th November 2005 01:55 AM
Peerless CSX 10 inch in sealed box or TL? ashok Multi-Way 12 23rd January 2004 10:24 PM
good sealed box size for a 10" Peerless XLS sub peerless Multi-Way 1 1st August 2003 09:01 PM
Copyright ©1999-2013 diyAudio
