4-way Active (3+1 way) TL 15" 8" 3" 1"
Old 21st December 2010, 08:58 PM   #1
cka3o4nuk is offline cka3o4nuk  Ukraine
Send a message via ICQ to cka3o4nuk
Default 4-way Active (3+1 way) TL 15" 8" 3" 1"
Hello community
just want to share my new project
4 way 2 different pars
Sub and 3way
wmtmw with tls
subs with tls
active filtering for some time mini dsp
the xo infrequences (50hz)-(500-800hz) - (3-3.5khz)
all drivers are Faital pro very good ts really
the tweeter new SB acoustics ring-radiator
FaitalPRO - Neodymium Professional Drivers
http://www.sbacoustics.com/index.php...29rdnc-c000-4/
the variant of case for that speaker in attach
plan to use Zen4 for midrange and tweeter and
lme49830 amps for woofer and sub-woofer
sub will work with hp filter 30hz-gd 30hz 10ms
woofer with 50hz hp gd 50hz-7ms
Old 13th March 2011, 05:05 PM   #2
After some time a project changed a lot
Woofer - B&C 15ps100
Mid-woofer B&C 8ndl51
midrange radian 950pb + Yurichi Arai A-300E horn
tweeter Foutek neo cd3.5
dac pcm1794 apergio h-cmos (10v outup)
amp for woofer LME49830 2 pairs of sk1530+sj201
amp for mid-woofer LME49830 1 pair of sk1530+sj201
tweeter amp - power follower 99 with 2ск1529 and 10uf output polyprop cap
midrange amp - power follower 99 with 2ск1529 and 100uf output polyprop cap
steped 8 chanel attenuator
Rlc correction for mid-bass and bass session
Old 13th March 2011, 07:50 PM   #3
Francec is offline Francec  Australia
Banned
Looks fantastic. What does it sound like and why are the bass drivers not recessed?
Frank
Old 13th March 2011, 08:01 PM   #4
the drivers will be recessed
it is 3d -model
Old 14th March 2011, 12:04 AM   #5
Banned
it is 3d -model
And it does look great.
Old 14th March 2011, 10:21 AM   #6
Top Shelf is offline Top Shelf  Canada
Top Shelf's Avatar
Wow !!!! What's the final colour?
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 14th March 2011, 10:27 AM   #7
DQ828 is offline DQ828  Australia
DQ828's Avatar
it is 3d -model
What program did you draw the 3D model in it looks real?
Old 14th March 2011, 10:33 AM   #8
3dmax+vray
the 3d-modeling is one of my real work.
all will be in cherry finish
Old 14th March 2011, 12:03 PM   #9
PaleRider is offline PaleRider  Norway
PaleRider's Avatar
Looks to have a great potential, but if it was my project I would look for a good 2-3" dome instead of the horn. Not neccesarely ATC but it shure would fit in.
Interesting sub-bass solution. Quarter-wawe horns are the only solution I`ve heard making a clean nin-compressed bass like my own build. Avoid absorbers
Old 14th March 2011, 12:25 PM   #10
listened a lot of domes vifa,tang-band,dayton, ATC they does not provide the sound i need
except atc all of them is just crap.
Driver +horn give a lot more resolution speed and detail
sub-bass without any absobers of course
mid-bass with
both mid-bass and sub-bass are in labyrinth like in first post
4-way Active (3+1 way) TL 15" 8" 3" 1"Hide this!Advertise here!
"Best" Woofer 50Hz - 300Hz & Hi eff, maybe 15" ?? bear Multi-Way 177 6th June 2015 07:16 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Hi Res 550mm Fresnel Lens Set, 15"x11" First Surface Mirror, 6.3" IR/UV Filter, More! Ben_Tech Swap Meet 0 22nd September 2007 10:49 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Copyright ©1999-2017 diyAudio
