I am looking for a proven design for 3 way floor standing speakers that have the full 20hz to 20khz range.
I am hoping to find something that uses efficient drivers and can produce decent spl. Most importantly I want to learn a lot in the process, so the design must be beginner friendly, but also attractive. I am open to All types of cabnets, OB Line array, Or any of the other more conventional setups. Size is not a problem as long as they are an attractive design. Price is not a huge issue, but as a beginner I'd like to keep it cheaper for my first attempt so maybe $1000 if that is realistic. Any help would be fantastic. Thanks!! |
#2 |
49 - for the 16th time
Hello feyrerm - What you are looking for is the ultimate quest for most of us!!! I've been there - and in many respects I am still chasing that shadow of "the perfect speaker". Building a speaker that will actually "do" 20Hz to 20 kHz is a challenge for even those of us that are experienced and educated in the art. Many speaker designs that will perform to those levels are around - but then some other things begin to rear their ugly head - things like "how come this speaker doesn't sound as good as I thought it would". One of the 1st problems will be that a three way speaker will use some sort of crossover network – either active or passive – and getting a handle on x’over design is a treat all by itself!
Look up the EconoWave project and see what you think. AK Design Collaborative - Econo-Waveguide Speaker - AudioKarma.org Home Audio Stereo Discussion Forums I think that it is a good place to start and there is a lot of support and other builders around. If you have the space and like the sound there are several good OB projects around here with MJK’s OB project high on the list – but that will get you back to some crossover design work that can be a challenge for even the experienced builder.
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod |
#3 |
The zaph sb12.3 should get you there....
https://www.madisound.com/store/prod...oducts_id=8691 |
#4 |
The perfect speaker doesn't exist. It will always be a compromise of advantages and disadvantages.
And then it becomes a question of what your taste is to make system you choose. TL,BR,BP,OB,ES,horn.closed. I build several systems and the best sounding on low and high level with good sound stage is a closed bandpass(fatboy project) low up to 80Hz. Dáppolito mid with titanium cone up to 2,5kHz. And 28mm softdome tweeter. Clean warm subbas bright detailed mid and silk high tone.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#5 |
Thank you for the suggestions so far!! Some good stuff to consider.
Please keep them coming! The more options I have to think about the better. Thanks! |
#6 |
Nice project, a 3-Way. It takes less than a year to build one and 20 to understand it. With a D'áppolito design add more 1-2 years of reading. Kudos brave man. You will need a good speaker for your "big" room/living room. Start from there for good integration.
#7 |
A visaton kit with the finest drivers available in the visaton range. Classic 3 way look modern drivers.
Glasfiber sandwich longstroke low Aluminium mid Ceramic dome high Conga ![]() Thd of the used AL130m midrange unit. As you can see highest level quality. ![]() Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 21st December 2010 at 05:36 PM. |
#8 | |
Helmuth, where did you get this information? id love to see the results for the AL130 alone, to compare with the al130'M'...
Im the guy that speaks in haste, and makes ill conceived theories, thinks math is a necessary evil, but i know something.Sometimes it bugs me, then i then i realise that theres 10 more just the same.So i guess Mulder was right. We are not alone. |
#9 |
This plot comes from the german magazine klang und ton.
#10 |
>>> And then it becomes a question of what your taste is... Totally agree! The two speakers you posted pics of probably each sound amazing but different. I can enjoy inexpensive speakers if they are decent quality, balanced overall maybe with a bit of a bass bump, without congestion or sibilance. Many fit that criteria so for me, there are many compromises i could enjoy. I am in the mood for some music now! |
| Proven DIY Line Array Design? | Ren | Multi-Way | 40 | 3rd June 2011 11:29 PM |
| Most Proven DIY Design? | abefroeman | Multi-Way | 18 | 25th February 2009 11:05 PM |
| Looking for a proven WMTW design or kit for HT L-C-R use | DTS | Multi-Way | 2 | 3rd January 2008 03:11 PM |
| Compress a proven design. | digital desire | Multi-Way | 1 | 20th November 2006 11:55 AM |
| Any Proven Transmission Line Design suitable for FE208Z | vangogh-hk | Full Range | 3 | 1st September 2006 04:52 PM |
| Page generated in 0.29773 seconds (30.90% PHP - 69.10% MySQL) with 11 queries |
