I was given a pair of Spica TC-50 speakers. I am quite pleased with their sound. I have built a number of speakers (Jim Griffin Jordan/Aurum Cantus Monitors, Metronome with Fostex 127s, ART Arrays), but none have the rock solid imaging of the Spicas.
After reading about them they seem to have a couple of unique qualities (at least in literature and interviews with the designer).
Has anyone come up with the DIY equivalent of the Spica's? Not necessarily the shape of the enclosure (triangle), but something that has the same design principles and results? |
#2 |
The term should be phase perfect or transient perfect here, as they use the 1st order filters, the only filters which are transient perfect. 4th order Linkwitz Riley crossovers, for example, are phase coherent, but they exhibit 360 degree phase shift.
I've not tried any 1st order designs, but I've come accross a few drivers that I've thought could be applied in such a design. Generally a woofer with extended upper range and smooth roll-off and a tweeter loaded with a waveguide could work. |
#3 |
Just had a look at the TC-50 spec sheet.
A 1st order hipass and a 4th order lopass, both drivers connected with same polarity. Off the top of my head that makes 270deg phase difference. Not sure how that makes them 'phase coherent'. |
#4 |
Probably they exploit the natural "phase travel" that even a single driver exhibits over it's operating range? If the range of the low frequency driver ends at 200 degrees, probably they made the high range driver at the same shift at the crossover point and then it is controlling the phase?
Is there an easy way of "guessing/predicting" the phase at certain frequency by just using a ruler to measure cone depth and a pocket calculator to calculate the delay? |
#5 | |
Usually you can relate the geometry with a group delay curve. That is, the difference in depth to the voice coils of the two units will give an air path delay that corresponds with the two plateaus that you will see in the group delay curve. Its hard to generalize about the phase curve in the transition region, since their are a number of options available when you design the system. With most pairings you can get a couple of combinations of rolloff rates and absolute polarities that work passably well. Each would have a different phase transition unit-to-unit. Outside of the crossover region phase is strictly determined by the drivers, their Hilbert transforms and their relative depth. David S. |
#6 |
Phase of each band pass is determined by the combined phase of driver and crossover. Both affect phase across the entire band pass. The way Spica designed the speakers was that the woofer response was tailored to a 4th order Bessel low pass response The Bessel response has constant group delay (linear phase) over much of its band pass. The 1st order HP on the tweeter was used because it has very little additional delay, but still, combined with the tweeter's natural response the HP is actually a 3rd order acoustic response. Anyway, Spica then offset the tweeter and staggered the crossover points so that the propagation delay at high frequency was the same delay associated with the Bessel LP section on the woofer. That is why the baffle is so sloped on the Spica. The result is something approximating a transient perfect design but the crossover still has irregularities in the crossover region. Additionally, since the tweeter offset is so great the TP behavior degrades rapidly off axis.
John k.... Music and Design NaO Dipole Loudspeakers. |
#7 | |
It's a suspended OB with adjustable tilt. Here it is: MJK’s Jordan JX92S OB with a Goldwood GW-1858 Woofer in an H Frame And here again: MJK’s Jordan JX92S OB with a Goldwood GW-1858 Woofer in an H Frame No one mentioned or asked about the tilt of the OB... and somehow I didn't mention it... The two supporting planks are pivoted and allow the OB to be tilted back up to about 20-30 degrees angle. Depending on the listening position I move the whole OB back and forth and tilt it to different degree or listen to it upright... And there definitely is difference, until I get it right the scene and imaging are partial. In my case almost always the vocals are centered and the guitars are well positioned. But my biggest problem is cymbals coming in front of my face, get it wrong and cymbals overtake the scene... The guitars and voices are less of a problem because I use the midrange as an extended range from 200-250 Hz to 7-10 kHz and I rely on their natural roll off and impedance peak after 8-10 kHz without a bandpass crossover - only first order single cap, Zobel, L-pad, high frequency extension circuit, baffle step compenstation and... and that's about it And actually adding a high frequency extension messed quite allot the imaging... In conclusion: tiltable OB or front baffle can show very good results for obvious reasons - altering the distance of each driver to the listener and thus the relative phase of the sound from each source. Best Regards! Last edited by T101; 18th December 2010 at 03:44 PM. |
| Are single drivers really phase coherent? | chuck55 | Full Range | 46 | 30th March 2010 06:03 AM |
| About a Nelson Pass phase coherent crossover | gaetan8888 | Pass Labs | 4 | 1st October 2007 10:44 PM |
| Phase coherent, low cost, 4th order XO | rick57 | Solid State | 20 | 15th April 2003 03:55 PM |
| Which 4th order XOs are phase coherent? Are SWs of value? | rick57 | Multi-Way | 0 | 14th April 2003 03:40 AM |
| Linkwitz-Riley 24dB/octave Phase Coherent Crossover | djdan | Solid State | 30 | 25th September 2002 10:32 PM |
| Page generated in 0.11042 seconds (81.19% PHP - 18.81% MySQL) with 10 queries |
