The smoothness and correctness of high frequency of the Pluto (clone) is quite well known, in fact it prompted changes to the uber-expensive Orions.
However their monopole bass means boomy, coloured sound. So what if I use the Pluto down to 100hz only then hand over to a dipole sub? It worked quite well actually! ![]() I thought the transition is not audible nor degrading. The plutos, being omni, provides very spacious imaging like dipoles. With one advantage, the sound does not shift when I walk around the room. They are the anti-CD of loudspeaker design. If JBL and Gedlee tries to have narrow beam as low as possible, the Pluto tries to have wide dispersion as high as possible. ![]() Subjectively the system renders much better midrange (vocals etc.) than every dipoles I've built. I thought some upper mids are cleaner with dipoles like piano recordings. Imaging is superb. I thought they are tall and wide but more sharper than dipoles.
http://gainphile.blogspot.com |
#2 | ||
Hi Gainphile,
Oliver
2Pi-online.de |
#3 | ||
Hopefully by then I will have a CD speakers too
#4 |
Andi,
Glad you are back modifying your Pluto clone. I had thought of making a pair myself, but after reading your thoughts, passed, thinking I already had something "better" for my needs. Now you have me thinking of trying a clone of this: Eight little Fountek FR88EXs, a couple of Neo3s, and my W-woofers......what do you think? Unfortunately, I've never heard an omni, so can you tell me how your omnis sound compared to your dipoles (if that's possible)? Thanks, Craigj |
#5 | ||
Ah, that yes, too ! Yes !
2Pi-online.de |
#6 |
An those Plutos look easy enuff to build
#7 |
#8 |
Hi Gainphile,
From my experience of building Pluto clones, I conclude the wider the tube, the better bass you will have. My first version was with a no-name 6’’ woofer I had in hand (watch attached picture). In this version I use a wider tube in order to fit the 6’’ woofer. Although it was lacking detail in the mids (because of the crap woofer) the bass was deep, spacious, without much coloration or booming. In my second build of Pluto clone, I used a 5,5’’ Jamo woofer and the recommended tube width dimensions. Result was better mids, not so low bass as before, but more boomy and coloration than before. YouTube - Pluto like Omnidirectional speakers.
Modesty is the art to make others discover how great you are. |
#9 |
Right now the problem builders are having is finding sources of parts. Most Siegfried Linkwitz designs are very parts sensitive. He worries about a 1/10 or 2/10 dB difference. In the US finding electronic parts is not easy and in Europe finding US size plumbing parts is imposable.
Kevin |
#10 |
My experience tells me that the Pluto design should sound enveloping for stereo. It would be cool to read a detailed, CHEAP, clone build. I don't think the magic drivers are very necessary--they may sweeten the deal, but any driver that will fit the directivity bill and have enough excursion/efficiency should do.
Dan |
| SL's Pluto | sdclc126 | Multi-Way | 122 | 22nd January 2011 04:08 AM |
| RS-232 cable for DSP-Amp Digisynthetic DSP-1400 | Sabbelbacke | Parts | 0 | 9th May 2009 09:33 AM |
| 3-Way Pluto? | sdclc126 | Multi-Way | 17 | 19th November 2007 01:31 PM |
| A Second look at SL's PLUTO | ScottG | Multi-Way | 26 | 25th October 2005 11:48 PM |
| Page generated in 0.11953 seconds (80.60% PHP - 19.40% MySQL) with 11 queries |
