I have been a lurker for a while, and I recently made an account. I have the DIY bug (it's bad!), and would like to build a tube amp and a set of speakers from scratch. I have a bit more lurking to do before we get into that (at this point, I am so overwhelmed, that I don't know where to start...).
In any case, right now I have a more immediate issue with my current home theater system is giving me a bit of trouble, and I was hoping to have some help troubleshooting it. The problem is that the tweeter intermittently goes out. I have purchased a new tweeter, but the problem persists. I have measured the resistance of the wires, and wiggled them quite a lot to see if the resistance would change, thus indicating a problem with the wire itself (I made that little test up, so if there is actually a legitimate way to test a wire, please let me know!). My skill set: I have a small grasp on electronics and ohms law. Basically, I can identify parts and give a high school explanation of their workings. I can also turn on my multimeter. I have attached a picture of the crossover, and have labeled the components just to make any needed communication easier. This x-over is the only thing between the tweeter and the source. This is a center channel, and the highs don’t go in and out in the R and L channels. Where should I look next?! Thanks. |
#2 |
I should also note that I have observed that the tweeter is more likely to cut out as the volume increases. That seems like it may a relevant bit of information.
Thanks again for any help. |
#3 |
Speakerholic
Flexing the board a bit to see if there are any cracks in the trace lines and resoldering all the connections on the board is the first thing I would do. It may just be bad solder joints. If you find a crack anywhere you run a jumper wire to bridge it. Also remove the wires from the terminals, strip and refasten.
#4 |
Cal,
Thanks for the help. It worked! The traces were in fine shape. I re-soldered all the joints on the xover and am now listening to a fully functional speaker. And, I learned something in the process... Thanks so much again! |
#5 |
Speakerholic
Cheers.
| Tweeter Mount & Diamond Audio Aluminum Tweeter | cnp112 | Car Audio | 0 | 18th November 2010 05:35 AM |
| Should a near-field use tweeter be different from a regular tweeter? | RockLeeEV | Multi-Way | 0 | 24th October 2010 09:43 PM |
| Why not a ribbon tweeter instead of a horn tweeter? | Curly Woods | Full Range | 9 | 15th July 2009 04:09 PM |
| Linaeum Dipole Tweeter as a Super tweeter? | ktuuri | Planars & Exotics | 5 | 17th June 2008 06:52 PM |
| Titanium tweeter vs Ribbon tweeter | goldyrathore | Multi-Way | 14 | 17th May 2004 07:21 PM |
| Page generated in 0.07761 seconds (82.07% PHP - 17.93% MySQL) with 11 queries |
