Old 14th December 2010, 05:24 AM   #1
bs1777 is offline bs1777  Canada
Post Crossover help
Please help. I have a 8 ohm amp with 2 channels. I recently bought some 4 ohm speakers to go with it. I want to cross it over but i dont want to spend much money. I found a good deal on a crossover that is 4 ohms. Being that me amp is 8 ohms, is it safe to connects the two, and if so what will be the side affects? My amp is a sony and if hooked up to different impedance speaker, after volume 20 it goes into protect.
-Thanks
Old 14th December 2010, 08:14 PM   #2
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
If your amp can handle no less than 8 Ohms, don't use speakers that are 4 Ohm.
You can damage the amp.
Your choices are to get an amp that can handle 4 Ohms or less or work with 8 ohm drivers and crossovers. The speaker drivers are what's dictating the impedance, not the crossover. The crossover is designed around the impedance of the drivers.
For example, in an 8 ohm, 2-way design that crosses over at 2000Hz, it will have different value crossover components (capacitors, resistors and coils) than a 4 ohm design.
Check out this calculator to get an idea of what's happening:
Passive Crossover Design Equations Formulas Calculator - Two Way First Order Network Butterworth
I build, therefore I am.
Old 14th December 2010, 09:42 PM   #3
Speakerholic
Cal Weldon's Avatar
Your sentence says everything.
Can you buy two more of those speakers and wire them in series?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 14th December 2010, 09:51 PM   #4
So if i hook up my 4 ohm crossover will i be good, or will i wreak the amp?
Old 14th December 2010, 10:23 PM   #5
re:'will i wreak the amp? ' - highly likely,
What do think the crossover will do?... Crossovers need to be designed for specific speakers, a 'a good deal on a crossover that is 4 ohms' is a waste of time, get your money back and buy speakers that match your amp...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 14th December 2010, 11:14 PM   #6
Pano is offline Pano  United States
Pano's Avatar
Strange that the Sony amp will not do 4 ohms, but going into protect mode tells you it can't.
Can you give more details in your speakers and the crossover you found? And what are your goals, apart from low costs?
Take the Speaker Voltage Test!
Old 14th December 2010, 11:34 PM   #7
-The crossover is electronic. It is a Audiopipe CRX-303. If you could tell me a little more about this crossover, that would be great. It says to be 4 ohms but will it still work with me amp? A pay very little for the woofers and i really like them and want to keep them. Thanks.
Old 15th December 2010, 12:00 AM   #8
vdi_nenna's Avatar
Your crossover is passive, high-level. It goes after the amp and before the speakers.
Is your speaker a three-way low, mid and high frequency drivers?
The crossover is not your problem. The amp is your problem. It can't handle the current of a low impedance driver(s). It over heats and goes into protection.
You need an amp like this one-
AudioSource AMP100 2-Ch Source Switching Power Amplifier | Parts-Express.com
It can handle 8 and 4 Ohms speakers...for the price of little more than 2 crossovers.
Old 15th December 2010, 12:28 AM   #9
I like my current amp but thanks for the reccommend. Is there any sugestions for a good cheap crossover that would work for my amp? And is there a way to make that crossover work?
Old 15th December 2010, 01:26 PM   #10
So would my 4 ohm crossover work with my amp? And i only need a 2 way crossover after some recent testing.
-Thanks
Which crossover is better? mondogenerator Multi-Way 16 17th May 2010 12:00 AM
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
need crossover help! PoorSound Multi-Way 13 12th February 2008 03:24 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.12304 seconds (80.54% PHP - 19.46% MySQL) with 11 queries
